Flex seal liquid
Discussion in 'Roof/Floor Repair & Maintenance' started by crazymama30, Apr 9, 2019.
  1. crazymama30
    crazymama30 Active Member
    473
    215
    Apr 1, 2017
    Has anyone used this? I have a little leak at both the front and back of the pup, and I was hoping to just pour some of this on real thick and hopefully seal the problem. Anyone have any thoughts?
  2. joet
    5,011
    1,077
    Pick up a tube of X Trm or Dicor. Flex seal might have a place, but not on a pup roof
    kcsa75, kitphantom, Raycfe and 2 others like this.
  3. Shaman1
    Shaman1 Well-Known Member
    2,236
    518
    May 13, 2011
    Oklahoma City, Oklahoma
    Go with the Dicor. Flex seal seems to turn brittle with sun exposure.
  4. crazymama30
    473
    215
    Apr 1, 2017
    Dicor is great, but I was looking for something to cover the entire roof with, I already sealed the seams.
  5. BikeNFish
    BikeNFish Well-Known Member
    3,822
    2,746
    Apr 24, 2017
    Maplewood, MN
    From the things I have been hearing about Flex Seal, it would be a mistake to use it in any camper maintenance application. It may work great at first, but it weathers quickly and will start causing problems in a year or so (looks horrible and starts to fail). Then you have even more problems when you have to remove it to apply the proper fix.
  6. Raycfe
    17,157
    2,762
    Sorry I am not a flex seal fan ....... for anything.
    nineoaks2004 likes this.
  7. kitphantom
    12,762
    1,799
    There have been quite a few who have done Grizzly Grip or the like to coat the entire roof. Same as, or similar to, bed liner products, made for the outdoors and has a much longer track record.
  8. BikeNFish
    3,822
    2,746
    Apr 24, 2017
    Maplewood, MN
    It just dawned on me that this can also describe my first marriage!
    kcsa75, Sjm9911, JPBar and 3 others like this.
  9. crazymama30
    473
    215
    Apr 1, 2017
    So grizzly grip is a better product?
  10. Shaman1
    2,236
    518
    May 13, 2011
    Grizzly grip is MUCH better, especially when covering large areas.
  11. crazymama30
    473
    215
    Apr 1, 2017
  12. Shaman1
    2,236
    518
    May 13, 2011
    Yes. That's the stuff.
  13. J Starsky
    J Starsky Well-Known Member
    967
    822
    Aug 3, 2017
    East Central MN
    I have a Flex Seal project on my dad's motorhome seam. Full width seam at rear of coach was letting water in small adhesive failures over time. I should get some 2nd year pics for you folks... I'm still on the fence but he told me to do it! I'm off the hook.
  14. crazymama30
    473
    215
    Apr 1, 2017
    I would be curious to see how it looks. I think I will go with grizzly grip, both products are expensive but less expensive than water damage!
    J Starsky likes this.
  15. J Starsky
    967
    822
    Aug 3, 2017
    East Central MN
    When the snow stops and I can pull his cover, I will let you know!
  16. vagov
    vagov Well-Known Member Gold Supporting Member
    4,669
    766
    Aug 13, 2012
    Pittsburgh, Pa
    I bottomed out 2 years ago, ripped my holding tank valve almost clear off where it comes out of black tank. , about 3/4 way around. I piece it back together to line up the cracks as best I could, did 2 applications of MEK then 2 applications if black flex seal liquid. granted the repair is under the camper, not exposed to the hot sun, but 2 years later still holding up strong
  17. littlebritches
    littlebritches Member
    65
    Apr 4, 2016
    WY
    Where do I find directions/recommendations on how to go about this? The website also shows "Prep solvent", "Water Base Sealer" and "Aerospace Primer". do I need all of these? Also, would you recommend course or fine? The only directions on the website are for fiberglass campers - mine is aluminum but they don't mention the solvent, sealer or primer at all.
  18. Shaman1
    2,236
    518
    May 13, 2011
    If you look at the grizzly grip web site for bed liners, you will find application instructions. Basically it is this:
    1.Remove anything you don't want covered and all the old finish
    2.Wipe with acetone (careful it's flammable)
    3.Sand with 220 grit sandpaper and rewipe with acetone. Let the acetone air dry.
    4.Apply the mixed grizzly grip with a roller.
    5.Fine gives you a smoother surface, course is more forgiving (your choice)
    Note: Wear a mask and gloves during the whole process.
    You can plan on however many days it takes you to prep the surface then, a solid day to apply the grizzly grip.
    Good luck. Steve
    littlebritches likes this.
