Floor Repair
Discussion in 'Roof/Floor Repair & Maintenance' started by Espeycaver, Oct 9, 2013.
  1. Espeycaver
    Espeycaver Member
    287
    Jul 12, 2011
    I have a 2000 Viking Saga and have noticed some rot on the floor along one wall. Its about 2' long and 3" wide running from one wheel well toward the front. You can notice a slight dip in the flooring inside the camper. Is there an easy way to replace the rotting wood without removing the camper walls? All I can figure out is I would have to remove the interior cabinets and water tank, pull up the linoleum and remove the flooring from the inside. Can it be done from the bottom?
  2. chris_keenan
    chris_keenan New Member
    Aug 10, 2014
    I was wondering how you made out? I'm facing a similar situation with mine.
    Chis
  3. Dubbya
    6,130
    78
    Aug 2, 2011
    Steinbach, MB
    Chris, take a look at the restoration thread for my '96 Viking Legend. The layout will most likely be a little different than yours but the processes, methods and supplies should be the same.
    I did a total floor replacement but putting in a patch between crossmembers is certainly doable as well. At any rate, I'm sure you'll find it of some assistance.
    http://www.popupportal.com/index.php?topic=56883.msg480691#msg480691
  4. chris_keenan
    Aug 10, 2014
    Thanks again. Think ill begin tackling it this weekend. I may end up doing the entire floor in as large pieces as I can
  5. banks412
    banks412 New Member
    104
    Sep 18, 2013
    Chris,
    Keep us posted on how this goes with some updates and pictures if you can. I too am wondering if I can replace the floor without having to remove the walls, etc...
    Thanks,
    Tim
  6. chris_keenan
    Aug 10, 2014
    will do :)
  7. mouse6196
    mouse6196 New Member
    180
    Mar 13, 2008
    Guelph Ontario
    Please post pics...I may tackle a soft spot on my camper (hybrid) and don't want to get into the wall issues.
    PICS PICS PICS.
