Floor Replacement - Adhesive Question
Discussion in 'Roof/Floor Repair & Maintenance' started by Steve Salowitz, Jun 4, 2021.
  1. Steve Salowitz
    Steve Salowitz New Member
    Jun 9, 2020
    I am have replaced the flooring in my 2014 Coachmen Clipper with plywood last year and I'm at the point where I can replace the flooring with new vinyl. I am debating if I should use an adhesive on the vinyl or keep it as a 'floating floor' and use the furniture and cabinets to keep it in place. Thoughts?
  2. Raycfe
    17,817
    3,296
    If you going under the cabinets I wouldn’t glue Otherwise the edges may curl. And if you do glue get a good sheet vinyl adhesive.
