Flooring question
Discussion in 'Roof/Floor Repair & Maintenance' started by JKUMike, Nov 20, 2020.
  1. JKUMike
    JKUMike New Member
    Nov 15, 2020
    We received this 1984 Starcraft from family knowing it needed some work (can’t complain about free.....yet). We knew there were soft spots on the floor and finally were able to pull back the flooring to see what we were looking at. If I push, I could probably go right through. So the big question: just go for replacing sections or would some type of wood hardener work?
    69127B58-5DB0-460F-A461-40553C6964F6.jpeg C24078CC-8D05-4A88-9005-1F1F33557922.jpeg
  2. WrkrBee
    4,571
    2,115
    Replace OSB (should not have been used by manufacturer) with marine plywood.
    Oh, welcome to the Portal from South Carolina.
    xxxapache likes this.
  3. JKUMike
    JKUMike New Member
    Nov 15, 2020
    Thanks! I’ve been glancing through since we picked it up last weekend. The more vinyl I pull up, the worse it is starting to look.
  4. KeizerTrailer
    KeizerTrailer New Member
    27
    18
    Aug 31, 2020
    Keizer, OR
    Replace with some good marine plywood. Definitely want to check elsewhere for leaks. My PUP had a leak in the left rear corner of the wall and it started to damage the floor.
