Ford Explorer Towing Capacity
Discussion in 'Tow Vehicles, Hitch & Towing' started by Emilie Lapierre, Aug 7, 2019.
  1. Emilie Lapierre
    Emilie Lapierre New Member
    Aug 6, 2019
    Hi,
    I’m new here and I have a question concerning my Ford Explorer towing capacity! Maybe some of you have experiment the same problem!
    It is written in the ford towing manuel that if the towing paquage is not original, we can’t tow more than 2000 pounds because we don’t have the thing that can cool the transmission.... but the installator of my kit keep saying that I can tow 4500 pounds with it! (A 2 inch hitch)... what donyou think about that? Everybody I spoke with is surprised with this
  2. PopUpSteve
    PopUpSteve Administrator
    18,907
    1,650
    Dec 22, 2002
    Malvern, PA
    I would think the installer was quoting the tow capacity of the vehicle in general. It's a good idea to have a transmission cooler in either case.
    1380ken likes this.
  3. Emilie Lapierre
    Aug 6, 2019
    Thank you!
  4. Snow
    10,175
    1,082
    For starters go to a Ford dealer and have them check the V.I.N , they should be able to tell what weight your specific vehicle can tow and the maximum tongue weight (along other weights that will be more important latter).. I assume by your posting your vehicle does not have a factory tow package nor a factory tow prep package, so even by adding a hitch, transmission cooler, power steering cooler you will still be limited to that 2000 lbs tow rating.. Since on many vehicles a tow package also includes things like stiffer suspension, larger alternator, larger capacity rad, different transmission shift points (most of these today are done by the "tow/haul" button if equipped), and different gearing in the differentials.. Again it does depend on your vehicle.
    NMroamer and RockyRoo like this.
  5. NMroamer
    NMroamer Well-Known Member
    547
    289
    Apr 21, 2016
    Albuquerque NM
    Thank you Snow for the first common sense answer to towing capacity question that I have seen here.
    So many take the tow capacity as gospel and put themselves and others in danger.
  6. Adam H
    Adam H Active Member
    391
    135
    Aug 22, 2015
    What year Explorer? FYI, after 10 years, Ford drops the vehicle information from their data base. At least they did until 2013 when I left. Go here and add your VIN https://www.ford-trucks.com/forums/vindecoder.php
    Depending on year, check your gear ratio tag on your rear axle cover, it will show what's there and if it's a locker or not.
    Ford didn't always install a hitch as part of the tow prep.
    What engine?
    Adam
  7. Emilie Lapierre
    Aug 6, 2019
    I add the towing paquage last week! It is not an original one! If I understand well, there is absolutely no possibility to rearrange my truck to be able to tow a 2500 pop-up... the guy who installed my towing paquage garanty me that i’m ok ... I dont know what he is talking about.... sorry for my english
  8. Adam H
    391
    135
    Aug 22, 2015
    Oh, and Ford put some pretty squishy springs in all the Explorers, so some help might be needed there with almost anything over a couple hundred pounds of tongue weight.
    Adam
  9. eoleson1
    eoleson1 Well-Known Member
    2,247
    681
    Jul 5, 2011
    Macomb County Michigan
    What year is your explorer? what engine does it have? is it two wheel drive, or four wheel drive?
  10. Emilie Lapierre
    Aug 6, 2019
    V6 3.5 L
  11. Adam H
    391
    135
    Aug 22, 2015
    Run the VIN in the link I posted.
  12. Emilie Lapierre
    Aug 6, 2019
    VIN mean serial number? Sorry hi Speak French
  13. eoleson1
    2,247
    681
    Jul 5, 2011
    VIN=Vehicle Identification Number
    Plaque d'immatriculation according to google translate.
  14. Adam H
    391
    135
    Aug 22, 2015
    Yes, it is the 17 digit serial number
  15. Emilie Lapierre
    Aug 6, 2019
    I juste tried to enter le last number wich is the serial number and it doesnt work...
  16. silvermickey2002
    4,671
    475
    Sep 11, 2008
    Morris County, NJ
    What year is your Explorer?
    We have a 2012 with a factory tow package. It's tow limit is 5,000. It has the V6.
    For those of you that have the Explorer. We just had a recall on it involving the rear toe links. Ford replaced them.
  17. Emilie Lapierre
    Aug 6, 2019
    No I dont have the factory towing paquage that why it is problematic
    QUOTE="silvermickey2002, post: 1296068, member: 16312"]What year is your Explorer?
    For those of you that have the Explorer. We just had a recall on it involving the rear toe links. Ford replaced them.[/QUOTE]
  18. Adam H
    391
    135
    Aug 22, 2015
    Verify the number with the sicker in the driver's door jamb or the number at the base of the windshield on the driver's side
  19. Emilie Lapierre
    Aug 6, 2019
    This? Its the same number as written on my insurances that I showed you
  20. JustRelax
    JustRelax Active Member
    996
    186
    Feb 20, 2013
    Indianapolis
    The person who installed the hitch may be giving you the rating for the hitch. Just because the hitch has the rating doesn't mean the vehicle does.
