Fresh water fill idea.
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by bheff, Apr 3, 2020.
  1. gladecreekwy
    927
    1,192
    Sep 25, 2016
    Jackson Hole
    Has it ever frozen?
  2. GreyFox
    GreyFox Well-Known Member
    2,210
    1,114
    Oct 10, 2018
    S Ontario
    No different than the pump in the trailer, just don't use it when temps fall well below freezing and stay there.
  3. gladecreekwy
    927
    1,192
    Sep 25, 2016
    Jackson Hole
    Looks different to me. Mines inside a heated space and the OPs pic has it in what is basically and out side uninsulated compartment. I’m afraid that if I pump water during the day and it gets cold at night I will damage the pump. Suppose i could blow it out with a compressor.
  4. nineoaks2004
    7,898
    3,497
    Dukes, Fl
    I purchased a 12V portable pump from Tractor Supply probably 15 years ago. , it has hose threads on both ends, I use it if needed for the TT, I also use it to empty the stock water tubs, I even used it to clear the water from a flooded shed.
    bheff likes this.
  5. GreyFox
    2,210
    1,114
    Oct 10, 2018
    S Ontario
    Can't imagine why you'd bother - if freezing is such a concern for you mount the pump in a portable box so you can store it anywhere the temps are above freezing. Wire the pump so you can plug it into the trailer's 7-pin connector OR if you prefer into your TV. You can wire in a switch to turn the pump on/off or simply plug ur into the power source when you want the pump to run. Pump input hose drops into your potable water source container (preferably with a draw tube that will pull all the water out). Connect a potable water hose to the pump output and stick it into the trailer's fresh water gravity intake - simple. [A] Here's a pic showing how I installed a pump in an unused metal camera case I happened to have on hand - I'd just park it on the truck tailgate and plug the 7-pin Bargman into the truck's matching 7-pin Bargman.
    artwolf and gladecreekwy like this.
  6. Raycfe
    17,005
    2,563
    You don't have to go to fancy ..... my wife uses one of these to water the window flower boxes ..... battery powered
  7. GreyFox
    2,210
    1,114
    Oct 10, 2018
    S Ontario
    Slow when you're transferring water in quantity. ;)
  8. gladecreekwy
    927
    1,192
    Sep 25, 2016
    Jackson Hole
    Nice. That’s where I’m heading. Does that pump have enough power to pull water through a 25 ft hose lifting approximately 3-4 and through an RV water filter?
  9. GreyFox
    2,210
    1,114
    Oct 10, 2018
    S Ontario
    Stock ShurFlo water pump, always worked for me whether I was pulling through 25' of potable water hose or pushing it. [A]
    gladecreekwy likes this.
  10. Jenkamus
    Jenkamus Active Member
    233
    60
    Oct 17, 2015
    Surprise, AZ
    This is the mod my husband is going to do on ours.
  11. artwolf
    artwolf New Member
    Jun 13, 2019
    Texas
    Wow, you have had a lot of trailers!
  12. nt40lanman
    nt40lanman New Member
    28
    Sep 9, 2015
    This is what I was thinking while reading through this thread. They are at least a couple gallons a minute, depending on how high you're pumping. We use this one at the shop for emptying and refilling fuel tanks.
    https://www.amazon.com/TERA-PUMP-AUTO-Stop-Protection-Batteries/dp/B00QVLQHAO
  13. bheff
    bheff Well-Known Member
    1,504
    911
    Feb 24, 2011
    NW Arkansas
    I see it is UL certified, hopefully it is intrinsically safe as well. They obviously designed it for fuel delivery so I'm sure the hazards have been mitigated.
  14. NoCal Camper Gal916
    NoCal Camper Gal916 New Member
    May 7, 2017
    Northern California
    These portable shop pumps advise against using for drinking water though. We don't drink per say the water in the pup, but do brush and rinse our toothbrushes...?
  15. Fshrmon
    Fshrmon Member
    42
    27
    Sep 4, 2019
    47.9790° N, 122.2021° W
  16. nt40lanman
    28
    Sep 9, 2015
    You could build a box with the pump, connections, a small lithium battery and a switch!!
  17. Snow
    10,740
    1,470
    For that price you can buy a cheap RV water pump and have a pump that is 12v and safe for drinking water.
  18. 98Roamer
    98Roamer Member
    87
    Oct 5, 2012
    FARfetched likes this.
  19. GreyFox
    2,210
    1,114
    Oct 10, 2018
    S Ontario
    Problem is, there's no way to ever fully dry out the interior of these collapsible water bags. Leave it long enough like that and mold is sure to form. [XX(]
  20. Snow
    10,740
    1,470
    Pour in a couple cups of bleach and water and slosh around a bit, then flush, just like sanitizing your water tank... I do it to my aquatainer every spring and once mid season..
