Fresh water tank cleaning, and gray water tank?
Discussion in 'General Camping Discussion Forum' started by crazymama30, Apr 21, 2018.
  1. crazymama30
    crazymama30 Active Member
    405
    174
    Apr 1, 2017
    Hello all. I did no use the water tank in my pup at all last year as my tow vehicle really could not handle the extra weight. My new tow vehicle can, so I want to use it at least for cooking and cleaning and such. I tried to search the forums but did not have much luck (I could have been using the wrong search terms). I am guessing I would use bleach to clean the fresh water tank, but at what concentration?
    Also, how does the gray water tank work, and could someone post some pics of one may be? That would be of great help.
  2. Snow
    10,094
    1,024
    Search this site or Google " rv water tank sanitation" or sterilization, you'll get lots of hits, including many youtube how to videos.
    Again, a search with the correct terminology is needed.. search the portal for "grey water setup" ..
  3. BikeNFish
    BikeNFish Well-Known Member
    2,853
    1,760
    Apr 24, 2017
    Maplewood, MN
    Check out THIS video.
    I sanitize my tank two to three times a year. I never use the tank water for drinking and never have in any of my past campers.
  4. Fixitup
    Fixitup Active Member
    386
    225
    Jun 7, 2016
    Not sure what the best way to clean. My only concern would be using bleach. I dont think the water pump would do well using bleach as it may damage the impeller and seals.
  5. BikeNFish
    2,853
    1,760
    Apr 24, 2017
    Maplewood, MN
    Bleach will have no negative impact on the water pump. You must run the water pump after you put the bleach/water into the tank because the water pump and lines will hold bacteria. If you don't run the pump when sanitizing you may as well not even sanitize the tank.
    My water pump has a filter that should be taken out and cleaned off every time I sanitize. It is on the pump or right next to it. If you get "slime" in your tank, the slime will clog the filter.
  6. crazymama30
    405
    174
    Apr 1, 2017
    Holy cow! Grey water tanks are expensive! That alone makes the decision for me.
  7. Raycfe
    15,189
    1,420
    If you don't have a grey water tank now, catch the grey water in portable tank or an Aqua-tainer jug.
  8. JPBar
    JPBar Well-Known Member
    1,870
    574
    Sep 22, 2016
    Texas
    This is my set up for the sink, cheap but it works. I do have a grey tote for the shower water though.
  9. nhlakes
    nhlakes Well-Known Member
    643
    317
    Oct 15, 2011
    DE and NH
    1/4 cup of bleach to every 15gals of water is a common way to sanitize freshwater tanks and suggested in many owners manuals.
    Portable grey tanks are not cheap ~$50 for a small 7 gal if I recall, and they have the standard hose connection your older starcraft likely has coming off the sink. There are all sorts of other ways to capture grey waste water, such as jpbar suggests. However, a larger portable grey water tote with wheels is easiest on the back and can be easily towed to the dump station. ;)
  10. cztardust
    cztardust Active Member
    856
    65
    May 29, 2013
    My 76 pop up has the original fresh water tank in it and I kept getting a whitish film in the water. I used the bleach and it seemed to help, but it was just way to gross to forget. Soooo....
    I bought a 6" screw in deck plate, cut a hole in the top of the tank and now I just unscrew the top and clean it all out.
    Best thing I ever did. Now I don't have to think twice about making my coffee in the morning.
  11. hq308
    hq308 Active Member
    143
    181
    Jan 30, 2018
    Sydney Australia
    Not sure if it's the 'right' way to do it but I just poured a bottle of baby bottle sterilizing solution into the tank and ran a hose from the pump back into the tank and let the pump circulate it for about 30 minutes. I then drained and refilled the tank a couple of times. In saying all that, despite the age of my trailer the water came out of the tank clean the first time I filled it, I just sterilized it to be on the safe side. We also only plan to use the tank water for cleaning.
