Freshwater
Discussion in 'General Camping Discussion Forum' started by countrymom, Jul 13, 2017.
  1. countrymom
    countrymom Member
    32
    Sep 22, 2014
    we are new so be kind Thanks in advance . Every time we fill our tank it drains water from the bottom , so don't know what the heck is going on would like to have it little kids .
  2. Boatnman
    Boatnman Well-Known Member
    1,444
    328
    Jan 19, 2017
    western Colorado
    Look under the trailer and see where it's coming from. It could be a drain valve for the water tank or drain valves at the low spots in the hot & cold water lines that are used to winterize the system.
  3. WeRJuliIan
    906
    90
    May 15, 2014
    Sarasota, FL
    ^^ x2
    Your water tank almost certainly has a drain, underneath somewhere.
    Usually a short hose with a valve on the end, more or less reachable by bending down and looking underneath.
    In the best case, somebody left the valve open, the last time the tank was drained, and all you need to do is close the valve.
    If you're less lucky, it may be a damaged water line or even the tank itself, but a drain left open is far more likely. I'd check for that before you start climbing underneath :)
    Ian, the man from Scotland
  4. Aladin Sane
    1,081
    109
    Jul 3, 2008
    Iowa
    The drain valve could also be found under one of the dinette seats if that is where the tank is found.
  5. countrymom
    countrymom Member
    32
    Sep 22, 2014
    Ok what does it look like under the bench ? Thanks
  6. JPBar
    JPBar Well-Known Member
    1,873
    580
    Sep 22, 2016
    Texas
    something like this.
  7. countrymom
    countrymom Member
    32
    Sep 22, 2014
    Thanks
  8. DigitalGuru
    DigitalGuru Active Member
    527
    30
    Jul 5, 2011
    Michigan
    Did you find it? Just FYI if you put your camper and tow vehicle make / model / year in your signature it will help people be able to accurately give information. Click on your username at the top-right of the page and click the "Signatures" section. Happy camping!
  9. countrymom
    countrymom Member
    32
    Sep 22, 2014
    Ok thanks ,yes we found it .
