Fridge question - mold!!!
Discussion in 'Miscellaneous Repairs & Maintenance' started by leningradka, Aug 25, 2019.
  1. leningradka
    leningradka Spending a small fortune to live like homeless guy
    264
    Apr 26, 2016
    Phoenix AZ
    I have a regular stock dometic fridge. After last couple of trips we have been battling mold invasion. WE have sprayed/cleaned and just cant seem to be rid of it. It seems that we need to remove the back portion of it - if the door is open, and you are looking in, its the piece that carries the metal "gills" in the back But we can't figure out how to remove it. WE would greatly appreciate advise on how to win this battle, we are going out this weekend and I can't use the fridge like this. Thank you!
  2. Pnut
    Pnut Member
    76
    34
    Jul 8, 2018
    NE Georgia
    I don't think you can remove those as they are part of the cooling system. Maybe you could use some type of bathroom cleaner for mold. Just make sure when you are done with each trip to leave the door open so it will dry out when it warms up and that should keep it from molding again. Just remember to close it when you get ready to pre cool it before your next trip.
  3. tzmartin
    tzmartin Well-Known Member
    923
    357
    Sep 9, 2015
    I put a container of charcoal in the fridge when it's stored.
  4. MNTCamper
    MNTCamper Active Member
    886
    189
    Jun 14, 2014
    MN
    Clean it right away and leave the door open as noted. Mold needs moisture to grow.
  5. Econ
    Econ Active Member
    285
    102
    Aug 18, 2019
    Deep South
    Clean with vinegar and leave the door open to dry out. The low PH of the vinegar will kill mold.
