Fridge won't light
Discussion in 'Refrigerators and Coolers' started by nfisherman, Aug 6, 2010.
  1. nfisherman
    nfisherman Member
    320
    Apr 23, 2005
    Illinois
    I have a Dometic 3-way fridge in my PUP. The last couple of times out, it didn't seem to cool well when operating on propane. I cleaned the gas orfice with alcohol and blew it out with compressed air. Then I cleaned the stack. Now it doesn't work at all on propane. I set it to propane and it does nothing. The ignitor doesn't spark and the check light comes on after a few minutes. I have checked all of the fuses and the battery is charged. I also tried it with AC power connected and I got the same result. I may have knocked something loose when I cleaned the orfice, but I can't see anything out of place. I can take it to a shop if I need to, but I'd like to find the problem if I can. Does anyone have any thoughts about where to look first?
    Thanks.
  2. Twisty
    Twisty New Member
    4,375
    Aug 24, 2008
    Hillsboro, Oregon
    Check for loose wires and make sure you have a good ground for the ignitor.
  3. SkamperCampers
    SkamperCampers New Member
    136
    Jun 29, 2010
    I don't know anything about a "check light", but my ignitor doesn't work so I just use a match. It also is usually helpful to run the gas for the stove for a minute or two to get any air out of the lines. After this, my firg usually lights with little problem.
  4. nfisherman
    nfisherman Member
    320
    Apr 23, 2005
    Illinois
    Never mind. I goofed. It was just air in the lines. I always open the stove burner for a while and I usually still have to try 3 or 4 times to get the gas all the way to the fridge. This time, it just took longer. I didn't see it light, but I turned the fridge on to the gas setting and by the time I got outside to look at the burner, it was lit. I even blew the flame out a couple of times and the ignitor instantly sparked and lit the flame again. It seems to be working fine.
