front running lights don't work
Discussion in 'Road Safety Systems' started by MOBYDICK, May 6, 2015.
  1. MOBYDICK
    MOBYDICK New Member
    May 6, 2015
    My 2 front running lights at the TOP of the trailer (see photo) won't light up. New bulbs and sockets look clean. ALL other lights working. I suspect a connector somewhere is loose, but have no idea where the connector is located/how to access it to check. Thanks.
  2. dshartsook
    dshartsook New Member
    May 16, 2020
    I’m having the same issue. My front lights work, but they will not blink for turn signals. I checked my TV plug with a voltmeter and hooked it up to a different vehicle. It was fine and is for sure the trailer. Not sure what to do and don’t want to take off the front plastic. I don’t need those lights, but worried this problem could eventually go to all lights.
  3. Snow
    10,532
    1,312
    Sounds normal to me don't think they should blink..
  4. Snow
    10,532
    1,312
    Check for wires running up in the canvas in the front 2 corners, there should be a connector.
  5. Raycfe
    16,436
    2,220
    My 2000 Cheyenne didn’t have and marker lights on the roof. What year is yours?
    Also the only lights that blink are the rear taillights
    Kyle R Thorson and bheff like this.
