Front Stabilizer Jacks
Discussion in 'Stabilizing Your Camper' started by lynnmarie0123, Jul 6, 2020.
  1. WrkrBee
    WrkrBee Un-Supported Member
    6,538
    3,448
    Drive the low wheel up on boards, interlocking pads, or other leveling device. Jacks can damage wires, plumbing, framework, floor, etc., if jack is used incorrectly.
  2. Steveo4090
    Steveo4090 Well-Known Member
    782
    735
    Jun 26, 2020
    Lancaster PA
    Like said above, its not a good option. The frames really aren't made for jacking like that. Use boards or lynx blocks or Anderson levelers. Bottle jacks especially are a bad idea because the camper can easily slip off it and serious damage and possible injury to people inside can happen.
  3. kitphantom
    13,216
    2,323
    We have used Lynx leveler blocks on both popups and our travel trailer. Our first pup was tiny, so we could have used a BAL only with an adaptation. The Lynx work very well for us, and we know, with some practice, how many to use from the look of the level bubble. We also use them under the stabilizers, to reduce extension and help on some surfaces. That first tiny popup used stack jacks, and pads of some sort helped there too.
  4. CajunMan
    CajunMan Active Member
    101
    71
    Mar 7, 2020
    And how people say GFI. What the heck is a GFI? I know what a GFCI is however
  5. Sjm9911
    10,626
    8,008
    Same thing, gfi was the original designation gfci came later. But there the same animal.
    tfischer and tombiasi like this.
  6. CajunMan
    101
    71
    Mar 7, 2020
    It just bugs me. Even safety coordinators in construction say this.
  7. Sjm9911
    10,626
    8,008
    Thats because they were taught gfi outlet. Then it changed. Lol. I say gfi also. So you probably can tell by the age of the person, with the terms they use.
    Kyle R Thorson likes this.
  8. tombiasi
    6,639
    2,209
    They are both acceptable terms. Ground Fault Interrupter, Ground Fault Circuit Interrupter
  9. Anthony Hitchings
    3,052
    1,807
    Mar 2, 2019
    Oakland, California
    how about “fantastic use of technology” , they really are great devices in a small package
