front storage drawer idea with external access
Discussion in 'A-Frame PopUps' started by Anthony Hitchings, Jul 17, 2020.
  1. Anthony Hitchings
    1,559
    807
    Mar 2, 2019
    The Basic Idea: (edits in italics)
    Forward of the dinette area, and/or under it, is a full width storage compartment. I have an idea to put in an access door on the outside wall at both ends of this compartment, put compact rollers on the ALiner floor - wheels up, and install a full with "U" box (about 73" long) that can roll at least half way out either (open) access door. This keeps stability issues easy and no fancy hardware is needed.
    This idea does not fully utilize the storage space as it exists today - but I very greatly detest the under seat storage features - and need to use the space somehow.
    Construction is likely all plywood, very little metal of any kind (except for fixed load bearing wheels). Maybe with fiberglassed corner seams.I may try PTFE tape for lateral guides (TBD).
    So that's it in a nutshell
    Any comments - let me hear them.
    BTW - I will add a full width plywood diaphragm on the fwd side of this cubby space to help with vertical strength issues - to compensate for the holes in the outside walls. This diaphragm will take outside wall loads back to the main chassis rails.
    DiamondGirl and myride like this.
  2. MEGEDH
    MEGEDH New Member
    Jul 17, 2020
    Northern California
    Like the option on the Forest River Rockwood A-Frames?
  3. Anthony Hitchings
    1,559
    807
    Mar 2, 2019
    Functionally - same as the option on the Forest River Rockwood A-Frames. But with more benefit - becasue it bypasses the seating area. That Rockwood has an accessible lift up lid - it does not need to be slide-out. Rockwood put money and trouble and extra weight into something that is not really needed.
    Econ and DiamondGirl like this.
  4. Strawhouse
    Strawhouse Well-Known Member
    1,604
    613
    Oct 4, 2015
    Muskoka, Ontario
    I had the same issues re storage access, so I added 2 baggage doors—one at the front driver’s side under the bench seat, and the other rear psgr side under the bed. Best move ever!
    DiamondGirl and Sjm9911 like this.
  5. Jim Whitehouse
    Jim Whitehouse New Member
    22
    Apr 16, 2018
    Guelph, Ontatio, Canada
    Have been pondering the same. Take out the outdoor shower add cargo door, access to under roadside bench. Area is catchall now. Increase organized storage.
  6. Anthony Hitchings
    1,559
    807
    Mar 2, 2019
    Jim
    any tips to offer on installing the doors?
  7. Sotovoce
    Sotovoce Active Member
    236
    115
    Jun 27, 2015
    Georgia
    I've seen pictures online where people have added the exterior access doors, but our Expedition came with 3, 1 under each dinette seat and 1 under the bed. Inside we never lift a dinette seat to access storage and only lift the bed infrequently since part of that storage is not accessible from outside. Those exterior doors are great! Keep looking and you should find the posts where others have installed the doors. I'm sorry I can't be more help.
  8. DiamondGirl
    DiamondGirl Well-Known Member
    623
    372
    Jul 2, 2016
    AZ Aliner
    Turtle3863 on YouTube added a new door to his Aliner and uploaded a video on it.
    Check it out...
    Happy Camping...[ALPU][PUT]
    Anthony Hitchings likes this.
  9. Strawhouse
    1,604
    613
    Oct 4, 2015
    Muskoka, Ontario
  10. Anthony Hitchings
    1,559
    807
    Mar 2, 2019
    The doors opened today, genrally well made, but not door is not totally aligned square with fame (tho each seems square in its own right). The piano hinges were screwed in place by the "Axe and Hammer School of Carpentry" - so I will flatten out the bent regions and reassemble them. I will leave the doors off while I install the frames (its so much easier). Size looks perfect insofar as cutting the opening
    I took the hinges off for some panel-beating. :)
  11. Mark U
    Mark U New Member
    Jun 25, 2020
    Not cheap but Lee Valley has some really heavy duty slides that might be useful (might have to split the width though): https://www.leevalley.com/en-ca/sho.../58870-double-locking-extra-heavy-duty-slides
    Alternatively, I just put a set of gas struts under the rear bench in my Aliner Ranger 12 a couple of weeks ago. Made a huge difference to how usable that space is, now it will move easily with one hand and then stay in pretty much any position. A lot cheaper too, I used a pair of these: https://www.princessauto.com/en/detail/56-lb-27-in-universal-lift-support/A-p8559288e (although I got them for $8.99 each on sale, still $12.99 isn't bad at all) plus some generic gate hinges. In my case I just hinged it across the back and the space works out that there's room for the cushions when it's open. If it's still awkward to get at you could probably do something a bit more complicated and have the lids rise up as well.
  12. Anthony Hitchings
    1,559
    807
    Mar 2, 2019
    Both doors installed - we will do the next trip without the sliding drawer (built/installed) and see if the doors alone are all that we need.
    DiamondGirl, TRR and BostonDad like this.
  13. Anthony Hitchings
    1,559
    807
    Mar 2, 2019
    I needed a cable management solution for the cables blocking the new drivers side cargo door - voila - several long screws and some zip ties to the rescue. On a side note - I wound up replacing one strut beside the cargo door with a deeper strut, notched to allow passage of the wires.
    TRR likes this.
  14. TRR
    TRR Active Member
    455
    224
    Nov 3, 2014
    Alabama USA
    Nice!
  15. DiamondGirl
    623
    372
    Jul 2, 2016
    AZ Aliner
    Cool modification.
  16. Steveo4090
    Steveo4090 Well-Known Member
    686
    615
    Jun 26, 2020
    Lancaster PA
    I use these at my house. They're great because they separate the different wires and clip shut. Convenient if you ever need to remove anything or add to it.
    https://www.amazon.com/Gardner-Bend...+nail+on+Gardner+bender&qid=1596393052&sr=8-4
  17. Anthony Hitchings
    1,559
    807
    Mar 2, 2019
    we are really enjoying the two cargo doors, and we have not even left the driveway. Now the trick is to not overload the tongue weight.
    So far, up front, we have:
    2 deluxe reclining camp chairs
    folding camp table
    Cleanwaste folding toilet
    40 ft extension cord for portable 100W solar panel
    30 ft security cable for same
    shore power extension cord (20A) and plug adapter
    2 gallons H2O
    and we may add:
    4 chocks and two levelling pads
  18. Anthony Hitchings
    1,559
    807
    Mar 2, 2019
    We finished two short trips over the Sierras - the two cargo doors are a real winner - I will not need to follow through on my original idea.
