Frustrated and done... what now?
Discussion in 'Camper Restoration Projects' started by JWeible, May 15, 2017.
  1. JWeible
    JWeible Active Member
    118
    61
    May 11, 2015
    We have had an '88 Jayco King 6 DLX for a year. The first time we tried to take it out and use it a cable snapped as we were lowering it after loading our gear. We were just finally able to afford to pay someone to fix it and used it this weekend. We had a great time and no issues. Went to pop it up when we got home to unload and the main cable snapped on it. We no longer trust this lift system.
    What to do now? Sell it and cut our losses? Is there some other type of lift system we can convert to that doesn't use cables? My husband kind of wants to turn it into a hybrid as thats what we would eventually like to move up to at some point, is that sort of conversion even possible?
    We are so frustrated and it was a devastating end to a wonderful Mother's day trip. Any advice would be greatly appreciated.
  2. jmkay1
    4,803
    1,683
    If you want a hybrid anyway I would just cut your losses and save up for a hybrid. The only popup that does not use cables would be the A frame type pop-ups or a true tent on wheels type popup like a quicksilver's. Have you tried to rent a hybrid to see if that is truly what you want?
  3. tfischer
    tfischer Well-Known Member
    3,513
    1,022
    May 21, 2014
    I think if you have someone look over the lift system and bring it up to spec it will be fine. Jayco's lift system happens to be my least favorite of the common ones, because they bury the cables inside behind cabinets, etc where they are hard to get at. But that doesn't make them inherently reliable.
    It's possible there's something else wrong with your lift system which is stressing out the cables...
    Also, don't even think of trying to "convert" your pop-up to an "always up" trailer. There's just too much involved, and the risk of failure far too high (think the thing blowing apart at 65mph on the freeway in traffic)
  4. Rusty2192
    Rusty2192 Well-Known Member
    864
    327
    Jul 30, 2014
    Kentucky
  5. JWeible
    118
    61
    May 11, 2015
    jmkay1- we have owned a TT and a PUP and borrowed a friend's hybrid. The hybrid is what we want for sure, just don't have the money.
    Tfischer- we did have it checked, they replaced several pulleys and brackets and one cable. This time the main cable broke. Not sure if they missed something or if thi things is just cursed :/ after further searching, the conversion is definitely off the table.
    Rusty2192- this may be exactly what we are looking for. Thank you!!!
  6. justincdst
    justincdst Member
    36
    May 20, 2016
    Have you tried to take it apart yourself? I pulled mine completely to pieces ('93 Palomino) and put it back together recently and it looks intimidating but its actually fairly simple once you wrap your head around how the cables push and pull on the springs. If the rest of the pup is in good shape, I recommend trying to repair it.
    DanielFlorida likes this.
  7. Halford
    Halford Well-Known Member
    3,563
    559
    Sep 28, 2011
    Santa Clarita, California
    Not all popups are created equal... some are easier to repair, some are NOT.
  8. justincdst
    justincdst Member
    36
    May 20, 2016
    Yeah absolutely, fair enough. I looked at a few lift systems trying to figure out mine before just saying the heck with it and tore it apart to figure it out. The principle are the same but yes they are not all created equally. Maybe I got lucky with the Goshen lift Palomino uses.
  9. JWeible
    118
    61
    May 11, 2015
    Ours has an L&W lift system. It's broken 3 times in a year. The last time was after having it fixed by a camper repairman. All trust is gone. We are going with the C&R lift kit.
  10. IngieBee
    IngieBee New Member
    25
    Oct 2, 2016
    I'd like to add that I didn't know myself, that the lift posts need to be lubricated with silicon spray as routine maintenance. My new to me Jayco was so hard to lift in o e Corner. After a good spraying and moving it around, and doing the other posts, we no longer have issues. BTW I also broke a brand new cable that I had just installed because of this. Silicon lubricant spray, says so in the manual, but I never see it mentioned in forums ☺️
