Econ
We were unable to camp much this year. Decided we would camp in the SMNP the 10 days before Thanksgiving, come hell or high water. About a week before leaving, the heater, a 7916 Mark 2 was tested to make sure it worked.
There is a post on the first time camper subforum several months ago where someone asks how cold is cold? Well, It depends.
The long range weather before we left showed one night in the 20's. Short story, we had 3 in the lower 20's and at least 2 in the upper 20's before losing count, WITHOUT a working heater. After working on the heater all week here is the conclusion. My factory thermostat didnt like to work if the temperature was cold in the beginning of the heat cycle. I went thru the thermostat and heater multiple times. Every contact point was checked with 800 wet and dry for corrosion. Never could find the problem till the day we were moving to someones cabin so it didn't matter. You could set the thermo at 100*F and it wouldn't come on.But if you set it for 70*F and jump started the thermostat it would work perfectly. All you have to do is jump the thermo til the gas valves clacked the first time and its good for the rest of the morning.
Its been in the lower 20's several times since getting home so for humor I would go out there and turn the heat on to no avail, til I jump it.
In the starting sequence the ignitor fires just after the gas valves clack. When its 50 ish it works perfect.Its only when it gets below "35" ish of so that this happens.
Tenters are crazy<GG>. We arrived at dark thirty and set up. The next morning we were the only camper there. We looked out upon a sea on tents.
How did we survive? It wasnt bad. We had a summer weight sleeping bag shoved inside a winter weight bag with a blanket on top. It was rather toasty til nature called at 2 am. I thought 20* would be colder. At 21* it did get down to 31* inside.
DW doesn't like the bag in a bag method so what is a decent thermostat replacement???????
Thanks
Thanks
