Furnace help!
Discussion in 'Miscellaneous Repairs & Maintenance' started by kmped, Dec 8, 2017.
  1. kmped
    kmped New Member
    Nov 6, 2017
    Fargo, ND
    Hello everyone,
    First time poster here. I am new to the pop-up world as I just purchased my first from a family member a month ago. I'm from ND, so we won't be able to use until Spring. I have a furnace question though and I'm sure someone will be able to help!
    My family member said the furnace should work, however they only used the pop-up during the summer so they haven't used it in years. She recommended I get the "pipes" checked out before using it. Can someone tell me what we need to check? Is this something we are able to do ourselves? (Boyfriend is very handy) or do I need to take it in? We will probably be using the furnace and don't want anything to happen!
    Model information: 2000 Jayco Eagle 10UD
  2. tombiasi
    6,383
    1,946
    Welcome. There is air intake and exhaust pipes as well as small places inside the unit that can get dust and spiders in them. I manual on your unit should show you what to do.
  3. xvz12
    xvz12 Well-Known Member
    922
    581
    Apr 6, 2017
    ID
    If it were me, i would check the flexible hose between the propane bottle(s) where it enters/goes under the pup for cracks or deterioration, the hard lines are most likely fine...other than that, check the furnace itself for dust bunnies, etc. Then follow the furnace's startup instructions, you may find it helpful to start & run the gas stove for a few minutes (if your pup has one), to bleed any air from the lines before starting the furnace. If you don't have the instructions for your furnace, if you get the make/ model# off of the furnace, you can find the operating manual via Google, or possibly here on this site. Good luck & happy camping!
  4. jmkay1
    6,508
    3,421
    I know the first thing to check it to make sure bugs/critters didn't make a nest in the vent on the side of your camper. Over the winter it is best to put a screen over it or pack it with steel wool to prevent the buggers from moving in.
  5. Pit 4 Brains
    Pit 4 Brains Member
    37
    Jan 1, 2018
    Mesa Az
    Look into the exhaust / intake on the side for debris. If there's none, send it some propane and fire it up.
    generok likes this.
