Gap in door
Discussion in 'General Camper Setup / Take Down' started by Kevin79, Aug 26, 2016.
  1. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    I noticed last night that the door on my camper doesn't close tightly. It looks like the top part of the door isn't level even though the sides of the door and the camper is. Any idea how to fix this?
    The floor
    Side of the frame (where it connects to the camper)
    Top of the frame
    Top of the door
    Side of the door
    Sorry they are blurry. Hopefully you can see the bubble on the level
  2. Snow
    10,136
    1,047
    It looks like a P.O of the trailer may have used the stabs to level a couple times and they tweaked the frame.. Not to much you can really do to adjust the door... Can add some weather stripping to fill in the gap..
  3. MrsGregg
    MrsGregg New Member
    Aug 13, 2016
    We found out on our last camping trip (after fighting with the door on multiple trips!) that we had our roof cranked up too high. A couple turns to lower the roof, and the door opened & closed with ease.
    I wonder if that could be the problem with yours too perhaps?
  4. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    I tried lowering the roof and it didn't help. The door opens and closes easily.
  5. tombiasi
    5,336
    980
    I didn't see most of the pictures. You said the camper is level, is the roof level?
  6. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    It is front to back. I can't check side to side until I put the bunks in on Sunday.
  7. drosengrant
    drosengrant One Day at a Time
    1,198
    22
    Jun 14, 2008
    Mine Hill NJ
    Is the door latch closing and holding door closed?
  8. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    Yes.
  9. rustybronco
    rustybronco Member
    179
    Jul 7, 2016
    So the gap at the bottom of the door is parallel to the floor and the same thing with the sides of the door and their corresponding panels's, is that correct? If that is the case, then the roof is un-level.
    You can check the frame's straightness with a string and three equal height spacer blocks.
  10. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    Not sure I follow. The door frame is level, the door itself is not. Specifically, the top part of the door (the part the folds up and attaches to the roof) is not level even though the corresponding frame is.
  11. tombiasi
    5,336
    980
    Like I said, is the roof level?
  12. rustybronco
    rustybronco Member
    179
    Jul 7, 2016
    Gap at bottom.... Same all the way across?
    Gap at left side... Same top to bottom?
    Gap at right side... Same top to bottom?
    I can see that the gap at the top isn't.
    What I'm trying to find out is if the door out of 'square' or is it the opening that's out of 'square' or both.
  13. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    No, the gap is worse to the left, away from the hinges. It also appears to be worse on the bottom.
  14. tombiasi
    5,336
    980
    Examine the door itself. Are the corners tight and square?
  15. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    I'll have to check when I get home and have access to a square. I'll have to see if anything can be done to the hinges.
  16. 91Starcraft
    91Starcraft Member
    141
    Apr 14, 2016
    We have the exact same
    Door, Startcraft right?
    Our does the same thing.
  17. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    No, the camper is a Jayco. I think I'll look into some weatherstripping, just to close the gap.
  18. rustybronco
    rustybronco Member
    179
    Jul 7, 2016
  19. Kevin79
    Kevin79 Member
    110
    Jul 3, 2016
    Michigan
    The bottom is because the wood is warped. Even with it pushed in tight, there is a gap up top. It looks like the top is crooked. I haven't had a chance to look closely at the hinges yet.
  20. rustybronco
    rustybronco Member
    179
    Jul 7, 2016
    Lots of clear concise pictures this time please. Possibly a long straight edge on the hinge side of the door to show if it bowed or not. Details showing a foot or so of an item may help clarify an actual latch but it won't help trying to figure out if the roof is swayed to one side. That requires a pulled back view as does a side view of the door and surrounding areas.
