Gas Alarm Peeping - and its not connected to 12V
Discussion in 'Propane - Got Gas' started by Anthony Hitchings, Jun 29, 2021.
  1. Anthony Hitchings
    3,054
    1,809
    Mar 2, 2019
    Oakland, California
    deleted - I was wrong - it was the (newish) smoke alarm peeping
    Sjm9911 and firepit like this.
  2. firepit
    firepit Well-Known Member
    2,545
    4,001
    Feb 26, 2020
    Reminder if you buy new...Take out the piece of plastic protecting your battery on your smoke alarm.
    Like a idiot i tested mine after i got it and nothing....I was mad that on a new camper my smoke alarm didn't work.
    Yes my wife even called me a Idiot[:D]
  3. Sjm9911
    10,641
    8,024
    Its hard to tell whats what. Lol. I totally get it.
  4. Anthony Hitchings
    3,054
    1,809
    Mar 2, 2019
    Oakland, California
    I am fed up withthis smoke-CO alarm. I went out to trailer to change tires - and the alarm is peeping (and trailer is closed up).
    Not the first time either.
    Batteries are fine - halfway inside the green zone on my tester.
    What a POS this thing is. :-(
    What make-model-other brand do y'all use that does not peep capriciously?
  5. Sjm9911
    10,641
    8,024
    Ok, so acording to the back of the alarm, why was it peeping? Was it a co alarm, low battery or fire? Or malfunction? Most of the battery, are cumulative, so they build up co over time and eventually alarm. You can try to blow it out with some compressed air, or just leave ot outside for a bit. Mostly, when they give put false readings, you just get another one.
  6. Anthony Hitchings
    3,054
    1,809
    Mar 2, 2019
    Oakland, California
    looking on rear of alarm - its closest to 1 chirp per minute whic means replace battery - which is bogus - battery status is both half way in the green zone on my fave meter and totally full of charge on two other meters. (all meters are different types)
  7. Sjm9911
    10,641
    8,024
    Then replace it. Or check to see if the prongs are bent out enough. And hit it with contact cleaner.
  8. Anthony Hitchings
    3,054
    1,809
    Mar 2, 2019
    Oakland, California
    if you look at the first photo - image 2311 - you can see that this alarm has a battery "caddy" - so there would also be contacts behind the rear of the caddy - I cannot remove the caddy unless I use a destructuve approach (or so it seems).
  9. Sjm9911
    10,641
    8,024
    Offset needdle nose should work.but it may just be easier to get a new one. They all malfuntion. Besides the plug ins with digital readouts, the more $$$ ones that need ac power. I haven't noticed a better brand then the next. They do make ones with 10 year batteries. But they go bad also.
