Gas flow
Discussion in 'Propane - Got Gas' started by Ted Matelski, Sep 21, 2021.
  1. Ted Matelski
    Ted Matelski New Member
    Sep 21, 2021
    Hey all, I am new to the camper scene. I bought an older used 2005 Rockwood pop up in really great shape. I've found my first issue.
    I have no problem lighting my stove inside or getting the heat to work. However, gas doesn't flow to the external grill hose, water heater or refrigerator. Any thoughts? I'm thinking trying to blow out the lines somehow. Thanks all!
  2. theseus
    theseus Living the Darkside... Silver Supporting Member
    3,354
    808
    Feb 6, 2007
    Centerville, OH
    Check underneath for a valve that can be turned off. Low pressure ports like the grill hose usually have a valve on them that has to be opened. It is also possible that the previous owner disconnected gas to those points.
    A picture of your tank/tanks and regulator would be helpful if you can get one.
