Generator suggestions
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by HappyCamperCanada, Sep 23, 2019.
  1. HappyCamperCanada
    HappyCamperCanada Member
    80
    62
    Aug 11, 2019
    Nova Scotia, Canada
    I'm not familiar at all with generators. I'm looking to buy a generator/inverter for my pup (Rockwood Premier 2514G). It must be quiet (something like a Honda ultra quiet). I'd like to be able to use my pup outlets when boondocking in the Fall. Specifically the heated mattresses. Pup has a 30 amp plug and I have a 20 amp adapter for it. Id like it to be able to run for at least 8-10 hours at night. Perhaps it could also be used to run a CPAP machine? Any suggestions for a quiet generator? Thanks
    Also, is plugging the pup into a generator going to recharge my batteries (like being plugged into shore power)?
  2. BikeNFish
    BikeNFish Well-Known Member
    3,497
    2,355
    Apr 24, 2017
    Maplewood, MN
    There are many threads on generators here on the Portal.
    HERE is just one of my many replies.
    In case you are wondering, a 2000W genny will NOT efficiently power an AC unless the AC unit is Less than 10000 btu. You will need to run the genny all night to heat your mattresses all night unless you come up with a way to run them off of batteries, but you will need several batteries as heated mattresses are energy hogs.
  3. GreyFox
    GreyFox Well-Known Member
    2,435
    1,260
    Oct 10, 2018
    S Ontario
    Don't kid yourself, NO generator is truly "quiet". You may want to run one all night long but you can bet your camping neighbours won't be happy about it and it's not uncommon for campgrounds to have limited generator hours anyway. Fact is, generators are man made mechanical devices that make all sorts of noise that even in the best of circumstances are bound the annoy others. Been there, done that.
    Your camper will have a converter that does charge the battery when the trailer is plugged into shore power - or god forbid, a running generator. [V]
  4. GreyFox
    2,435
    1,260
    Oct 10, 2018
    S Ontario
    While that used to be the case this is no longer true - add a Micro-Air Easy Start Soft Starter Kit to the A/C and a 2K genset will easily start a typical 13,500 BTU roof mounted A/C, even in higher ambient temperatures and at higher elevations.
    https://www.microair.net/products/e...rter-for-air-conditioners?variant=30176048267
    I've owned 2 different Honda EU2000i gensets but if I were buying another this time around I'd invest in the new Honda EU2200i which will easily handle this task - no longer is it necessary to use the typically recommended 3500 watt genset for powering one of these A/Cs.
  5. WVhillbilly
    WVhillbilly Well-Known Member
    841
    632
    Jun 6, 2018
    WV
    Having spent a weekend at a campground where someone was using a very nice, quiet, Honda generator to power their AC. It really wasn't that quiet.
    Now it's not idling diesel truck noisy, but at night in a quiet campground it will surely be heard a lot farther than you think.
    If you are truly boondocking, and the only one around I'm sure it would be fine. Since you're the only one it's going to bother.
    For something small like a CPAP or heated mattress one of the Predators from HF would be fine.
    The "cheap" China generators are a lot better than they used to be.
  6. BikeNFish
    3,497
    2,355
    Apr 24, 2017
    Maplewood, MN
    Nope. Just because you can, doesn't mean you should. Good luck to you if you choose this path.
  7. Bradley E Dixon
    Bradley E Dixon Member
    53
    73
    Jul 1, 2019
    Minot, ND
    HEY! Go easy on the the "cheap" analogy...lol
    I started out with a GENERAC 2200 to run A/C - CPAP(s) and any other electric device(s) and I thought it was pretty quiet. UNTIL we realized it couldn't run everything, and ran out out gas about every 4-5 hrs.
    So I researched/google'd the crap out of QUIET 3400+ inverter/generators and decided on the HF (Harbor Freight) PREDATOR 3500.
    $699 w/coupon out the door.
    I am still amazed at how QUIET this thing is compared to other(s). It purrs.... (the only description that fits it) and has no trouble running everything we need/use when going primative/boondocking.
    Put close to 140hrs since it was purchased. Followed the break-in instructions. Changed oil to a high ZINC synthetic and new NGK plug. Run NON-ethanol premium fuel with SEAFOAM. And drain the carb when stored.
    A++ rating IMHP and for the ridiculous low price.....can't go wrong.
    My 2cents
    Good luck.
  8. HappyCamperCanada
    80
    62
    Aug 11, 2019
    Nova Scotia, Canada
    I don't have an AC unit. Furnace and heated mattresses and a CPAP machine would be the only draw
  9. HappyCamperCanada
    80
    62
    Aug 11, 2019
    Nova Scotia, Canada
    Can't get the HF predator in Canada apparently.
  10. HappyCamperCanada
    80
    62
    Aug 11, 2019
    Nova Scotia, Canada
    Truly boondocking. Nobody else around.
  11. SteveP
    SteveP Well-Known Member
    1,748
    541
    The thing about the inverter generators is that they are quiet when they are idling and putting out low wattage. When they ramp up to provide heavier load they do get louder, just not as loud as a contractor generator.
  12. HappyCamperCanada
    80
    62
    Aug 11, 2019
    Nova Scotia, Canada
    Does anybody know what kind of wattage the pup heated mattresses pull? One is a king and the other is a queen?
  13. xvz12
    xvz12 Well-Known Member
    891
    539
    Apr 6, 2017
    ID
    We don't have air conditioning in out pup either, so we bought one of these:
    Sportsman 2200 watt dual fuel generator
    They're considerably less if you wait for them to go on sale. I bought ours mainly because it would run off of propane, don't have to worry about it going bad in storage. I doubt I'll ever run it on gas, unless its a 'have to' situation. It's relatively quiet, if boondocking I wouldn't think twice about leaving it running if I needed to, but I try not to run it when we're in a campground. We have 200 watts of solar cells on top of our pup charging the battery bank, so the generator is essentially a fail safe for us.
    HappyCamperCanada likes this.
  14. Spridle
    Spridle Well-Known Member
    1,184
    381
    Jun 6, 2011
    heated mattresses and boon docking just sounds like a bad combo to me. I'm sure it's resistance heat, which is a heavy draw. But there has to be rating on it somewhere, by law. From there it's just math. Same with the cpap, flip it over and look at the draw on the label. It's not much. For just furnace and cpap, I suspect a 1000w gen would run at idle without ever ramping up.
  15. SteveP
    1,748
    541
    Get a watt meter and measure it yourself. They're available almost every where, including Walmart, Harbor freight, Lowes.
  16. WVhillbilly
    841
    632
    Jun 6, 2018
    WV
    Communists
    Come for a camping trip and smuggle one back [:D]
    HappyCamperCanada and davekro like this.
  17. gladecreekwy
    1,012
    1,358
    Sep 25, 2016
    Jackson Hole
    I “truly “ boondock every time I go camping and I’d never have a generator. It would bug ME.
    Spridle likes this.
  18. WVhillbilly
    841
    632
    Jun 6, 2018
    WV
    We used a 2K watt Predator all Summer on a construction site.
    It sipped gas, ran about anything we plugged into it, got the oil changed once, and is still humming along quite well.
    For $500. You could carry it with one hand too.
  19. HappyCamperCanada
    80
    62
    Aug 11, 2019
    Nova Scotia, Canada
    We Boondock all summer and into the Fall running off batteries, propane and solar. But now that temps are dipping into the low 30s and days are getting shorter it's time for a boost. My solar set up can't keep up.
    gladecreekwy likes this.
  20. HappyCamperCanada
    80
    62
    Aug 11, 2019
    Nova Scotia, Canada
    I'm going to go with a Champion 2000W generator. They're on sale right now. 58 dB isn't too bad for noise level. There's nobody near us and I can live with the drone if it means camping longer into October and keeping warm.
    Snow and gladecreekwy like this.
