GFI keeps tripping
Discussion in 'Wiring' started by randy_1981, Jul 12, 2019.
  1. randy_1981
    randy_1981 New Member
    22
    Mar 30, 2019
    Indiana
    Well, the problem turned out to be crossed wiring. I guess I had too much pride to go back and check my work at first =p. Thanks to all who have helped, and if you ever find yourselves in northwest Indiana, give me a shout, and I’ll but you a beer! Likewise, if you’re ever up this way, try and camp at Indiana Dunes State Park. It’s right off Lake Michigan, you’ll think you’re at the ocean! Thanks again!
  2. Fless
    Fless Active Member
    948
    195
    Aug 14, 2012
    Colorado
    Glad you got it fixed, and thanks for posting the solution! Happy camping.
    _
  3. brwarrior
    brwarrior Active Member
    171
    73
    Mar 26, 2017
    Clovis, CA
    Just so people understand what a GFCI receptacle is doing. It's measuring the different in the current flowing through the hot and neutral and trip at 5mA (.005 amp) difference. They don't care about the ground and in fact are required by the National Electrical Code (USA, no idea what CEC requires for our friends to the north) when you replace an old two wire receptacle (NEMA 1-15, 1-20) without a ground with a receptacle with a ground pin (NEMA 5-15, 5-20). New current generation GFCIs will not reset if the wiring is incorrect, as noted by the OP's post.
  4. eoleson1
    eoleson1 Well-Known Member
    2,246
    680
    Jul 5, 2011
    Macomb County Michigan
    When I read the title of this thread, my initial thought was "LSD in the electrical supply?"
    Don't judge.
