good way to remove decals
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by brit, May 28, 2011.
  1. brit
    brit Loving-Life
    181
    Mar 14, 2011
    We are currently repairing a roof on our Starcraft, nothing major, but it does need to be re-painted, anyways, there are decals on both side ends, I removed them by using my hair dryer to soften the glue on the backs and they came off easy with a little persuasion lof a plastic scraper, took 5 minutes to do both Starcraft lettering.
  2. zx5chris
    zx5chris New Member
    Mar 20, 2011
    ya, i've used a heat gun and bubbled the finish on door. oops! finished with a hair dryer [CF]
  3. marcort
    marcort New Member
    33
    Mar 28, 2011
    I used a hair dryer too. Was a bit a pain because I pulled pin stripping that had been hit with debris from the TV for years. So every time I'd start to get a piece of it, it would break off. Ugh... Took me all day. You should post some pics.
    Here's what mine looked like when I was in the middle of removal.
  4. robinsonfam1
    robinsonfam1 New Member
    63
    Jul 28, 2009
    gRAYSON, GA
    kutzit.
    found at ace hardware and other places. sherwin williams.
    get small bottle. you will be done in one hour. will need to make sure you prep camper properly before paint and be sure to use something to remove residue left by kutzit. it leaves an oil behind. i used greased lightning then tsp double dose after using wire wheel on entire pup.
  5. nomoretent
    nomoretent Member
    387
    Jun 5, 2011
    There is another thread on this. Kutzit is AWESOME!!! And they have it at ACE. Just be sure to let it sit for 20 minutes before you try to peel anything off.
