Goshen lift post replacement
Discussion in 'Lift Systems' started by mread5, Jun 10, 2016.
  1. Hoyt Burrass
    Hoyt Burrass New Member
    May 9, 2018
    Montgomery AL
    I believe from your description that you need to put some supports in (4, 2 front/2 rear) to hold the roof off of the camper. I used cheap 2x3's from Lowes Depot. you may have to cut them to get the lengths to match up...on my Rockwood the front and rear are not the same height. Rest them on the ground and allow yourself plenty of room to work...in other words...longer rather than shorter. Mine are all over 6 feet long.
  2. Robert Hornung
    Robert Hornung New Member
    Aug 23, 2019
    Thanks, I really appreciate your response but the roof is already off the camper. The sides rotted away and, while raising it, the roof shifted and fell apart. So now I am building a new frame for the roof. I know the roof brackets are slightly bent but the face of the brackets sits even to the front of the posts. So if I lower the lift posts all the way down, the wood sides rests on the top rail of the camper. If I only lower the lift posts to about 6 or 8 inches above the camper rail, the wood sides are just barely outside the camper. There were no spacers between the original wood sides and the roof brackets so I'm kind of stuck.
  3. Hoyt Burrass
    May 9, 2018
    Montgomery AL
    Can you post some pics...I'm not clear on what you are describing...also heading out with kids, may be a while before I respond
  4. Robert Hornung
    Aug 23, 2019
    Sure here a 4 pictures. The last one is a piece of wood on the outside of the camper. You can see the gap between it and the roof bracket. Whenever you get a chance, I greatly appreciate it. Enjoy family time.
  5. Hoyt Burrass
    May 9, 2018
    Montgomery AL
    Hi Robert...the pics do help. Unfortunately, I'm not familiar with the geometry of the dutchmen 1204 roof sideboards but I did find this thread from 2013 that may point you in the right direction. IIRC our Rockwood does have a flair that fits over the outside of the camper rail. I am sorry that I am not more help...you might message the member that posted the dutchmen thread above if you need more help.
  6. Robert Hornung
    Aug 23, 2019
    Thanks for the thread, it definitely helps. I appreciate your help. I spent the yesterday cutting out the sides and and attaching them to the sides. I still gotta cut out the front and back sections and attach them. I'll reach out to the member and see what they say. Thanks again.
  7. Heather Panowicz
    Heather Panowicz New Member
    Feb 3, 2020
    Baltimore, MD
    I have unfortunately found myself in this position. I recently bought a 1998 Viking 2470 Legend. When we were popping it up we noticed that the roof was uneven despite making sure we were level. We discovered that the two lift posts on the door side have unattached (see pictures). We know we need to replace the side board. We would prefer not to take the whole roof off because we do have an A/C unit and the other side is in tact. Here's what I'm thinking:
    Raise the roof and remove the canvas and interior curtain attachments
    Lower the roof and replace the sideboard
    Raise the roof and use 2x4's to keep door side up and safety bars to support good side
    Remove broken posts and replace with new posts using mread5’s directions
    Does this sound right? Any suggestions or input would be greatly appreciated.
  8. Hoyt Burrass
    May 9, 2018
    Montgomery AL
    Hi Heather, I've not done a sideboard replacement...though many here have and you can probably find info by wading through some search results. The only comment I can make is that when measuring your 2x4's to keep the roof up, watch for a difference in the length needed to support the front and back. Ours was different by a couple of inches...so don't just measure one and cut both......best of luck.
    BikeNFish likes this.
