Goshen lift system....side to side level
Discussion in 'Roof/Floor Repair & Maintenance' started by smoreking, Apr 30, 2013.
  1. smoreking
    smoreking Member
    400
    Sep 15, 2009
    Small Town, Middle TN
    I'm searching for info on why my roof always leans to the door side. I haven't measured the height side to side because I don't think there is an adjustment for that anyway. Pup is level and almost always when I set up the door I have to pull the roof over to the door. I mean that the roof may or may not be level in height but its like the lift post have slack and the door itself is what keeps everything straight. This sometimes causes problems by the plastic tabs that are on the door coming loose and the roof leaning away from the door a few inches. Does anyone else have this problem or a solution?
  2. yetibiker
    yetibiker Darksider, family adventurer
    85
    Aug 12, 2011
    I have that problem.
  3. sabragg
    sabragg New Member
    May 25, 2013
    Sorry I cannot help either, but know you're not alone. I have that problem too.
  4. boxdoc2
    boxdoc2 New Member
    Aug 24, 2013
    I'm glad to know I'm not the only one who has this issue. I can literally push the whole top of the pup toward the curb side and it's level but so far have not figured out a way to keep it there. Do all of you have a roof top a/c unit? I'm wondering if it's the weight.
  5. shelmily
    shelmily Well-Known Member
    3,477
    405
    Jun 7, 2012
    Northeast Pennsylvania
    If the AC is not centered on the roof, That could be the problem. I would call Goshen directly, and ask them what they think. I have dealt with them in the past. They are very helpful, and have great knowledgeable support people. Here is there info. http://www.goshenstamping.com/lift.php
  6. Camp-N-Nuts
    Camp-N-Nuts KrustyKamper
    2,025
    Aug 9, 2011
    Central WI
    On our "G-System" it needs to lean slightly to the door side (not level) so the door opens properly...in other words, the top and bottom hinge will not align and the 2 pieces separate at the handle side. As you open the door...it will pull the roof toward you!
    I have no AC on mine. This is just one of the quirks you have to get used to with a used pup! [V]
    I hope there is a fix! [RTM] [MOD] [PU]
  7. dksimon
    dksimon UNITED WE STAND
    146
    Aug 13, 2010
    Lewisburg TN
    I have the same problem with mine! I thought it was due to the A/C weight on the roof. Mine leans to the curbside and the A/C is on the roadside.
    Interested in others with thoughts on this problem!
  8. Camp-N-Nuts
    2,025
    Aug 9, 2011
    Central WI
    I haven't tried this (just a thought process)...raise the roof higher than needed and put longer support poles street-side...set the door...then lower the roof slightly to get a curb-side lean! [?]
