Gray water tank storage
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by HenryJ, Aug 3, 2011.
  1. HenryJ
    HenryJ BLT Offroad
    155
    Jul 8, 2011
    I decided that we might find a gray water tank useful. A suitable place to carry it out of the way was needed. I did lots of looking and found nothing similar to what I had in mind. I really did not want to lose space on the deck. Lifting it up there was not something I was looking forward to either.
    [​IMG] [​IMG] [​IMG] [​IMG]
    Hanging it underneath seems like a good idea. We won't need it all the time and it will be handy when we do. The aluminum diamond plate tray hangs down an inch lower than the fresh water tank. No lower than the stabilizers or the accessory tube that we mounted just in front of it.
    Hinged on one side the ramp makes it easy to deploy and "I hope" easy enough to stow.
    I decided that a ten gallon tank would be enough. That is half the fresh water tank. The size is right to fit underneath without hanging down too low, or being too heavy to stow when full.
    Just thought I'd share the idea. Good , or bad? Time will tell.
  2. mdigby
    mdigby New Member
    279
    Sep 9, 2007
    looks like a good idea! I'll have to take a look under my camper to see what I can figure out!
  3. smellott
    smellott Livin' in NH but a WV Mountaineer for life
    285
    May 11, 2009
    Southern New Hampshire
    Nice job Henry. How are you securing it while in transport? Have you tried towing with it attached yet? Curious if you can hear it rattle.
    NHeer
  4. HenryJ
    HenryJ BLT Offroad
    155
    Jul 8, 2011
    THX!
    The tank just rides in the tray. I doubt that I will need to stabilize it further. If it needs some help I may attach some high density foam blocks to the interior. The hinged latch/end is weighted to remain closed, however I did attach Tee handle draw latches to either side to keep it closed tight in the rough stuff.
    I have not towed it since installation. The tank moving around inside the tray is all that could rattle. The tray is very solid once raised. I did not want it loose , that could be a problem in the long run.
    I am very sure that there is no way I would hear anything from it, even in the really rough offroad stuff. Well, maybe gravel hitting the diamond plate. It would be hard to tell where that was happening though ;)
  5. yogi
    yogi New Member
    708
    Aug 13, 2008
    Portland, Oregon
    Now that's brilliant!
  6. Hyperterex
    Hyperterex Active Member
    1,023
    Jan 1, 2010
    Great mod, nice job
  7. HenryJ
    HenryJ BLT Offroad
    155
    Jul 8, 2011
    I apreciate the kudos, thx.
    Here is a picture of the latches:
    Rubber Tee handle draw / hood latches, small (2.5")
  8. johnlely14hw
    johnlely14hw New Member
    652
    Apr 7, 2011
    Nice mod!
  9. wcasey5
    wcasey5 New Member
    197
    Apr 26, 2007
    Westminster, MD
    A hA! Thought I recognized you. Excellent mod, your's came out much cleaner than mine. As I mentioned on the other site, I towed this setup approx 1100 miles or more so far this summer with no problems. I was going to make something like yours to hold my tank, but then I figured I would always be carrying an empty tank so I just used chains. This is what I did.
    http://www.popupportal.com/index.php?topic=47474.msg355336#msg355336
  10. CarNutCass
    CarNutCass Put a little gravel in your travel
    805
    Mar 20, 2009
    St. Charles
    Nice work!
    I've been considering a portable poo tank for those times when we stay at an electric-only site for an extended period. I'll have to look and see if I'd have room for something like this. [:)C]
  11. jrclocks
    jrclocks Member
    585
    Jun 24, 2008
    Great Idea!
    The photos may be deceiving, but it appears that the latch end of the tray is near the center of the camper and the hinged end of the tray is near the side of the camper by the steps. Do you have to reach very far under the camper to raise and secure it? If so, maybe you could switch the ends so the hinge was near the center and the latch was near the side of the camper. Since you're using a steel rod to attach it to the camper frame at each end, this seems like it would be an easy change.
    Let us know how it works for you.
    My [2C],
    JR
  12. Storm Trooper
    3,544
    Feb 14, 2008
    Very nice job....
  13. jwolfe01
    jwolfe01 Honeoye, NY
    779
    May 5, 2008
    Honeoye Falls, NY
    Nice job, I am going to do something similar on my TT. I have seen others do it and its a great way to carry the tank.
  14. haroldpe
    haroldpe Campin' Engineer
    854
    Mar 21, 2004
    Adamsville, MI
    Wow- really well done installation. You're right, when you don't use something every trip, it makes wasted effort to have to move it twice every setup/teardown.
  15. JenP
    JenP New Member
    38
    Sep 30, 2007
    western Pennsylvania
    Nice work! Thanks for sharing.
    Do you think this would work to haul home a full gray water tank? Sometimes we primitive camp where there is not even a dump station and have to take home the gray water. Currently the only place to store the tank (empty or not) is inside the camper, under the couch.
  16. HenryJ
    HenryJ BLT Offroad
    155
    Jul 8, 2011
    I do and I plan to carry mine full to a dump station stowed in that position. That was my intent from the beginning.
    I have a small front deck , but with a cooler up there, I would have little room for the tote tank. I have other things I would rather do with that space. This solution stows the tote tank in an otherwise wasted space. It sure seems like a win? My only concern will be the amount of dirt, mud and debris that may accumulate in that tray. I thought about drilling large holes in the bottom, but decided to "play wait and see."
    I will know much more after completion of our next expedition planned for late August. Trial by fire so to speak. It will get a good test.
  17. RFryer
    RFryer Hopkinton, MA
    762
    Mar 10, 2009
    Hopkinton, MA
    HenryJ,
    Was this assembled with welding or mechanical fasteners? Do you remember the thickness of the diamond plate you used and how is it working now with some use? Great idea, I'd love to do this to mine!
  18. HenryJ
    HenryJ BLT Offroad
    155
    Jul 8, 2011
    The aluminum diamond plate is welded. It is the bottom portion of a bedside tool box that I recycled. I am guessing the diamond plate is about .090" maybe? 3/16" thick or less?
    I am sure you could assemble it with pop-rivets too. Maybe find a cheap toolbox on craigslist?
    It has been working GREAT. Sure nice to have it tucked out of the way. I have not needed to haul it loaded yet. I have been able to dump it, but I am sure I will get to test that eventually.
  19. phalynx
    phalynx Member
    284
    Aug 27, 2011
    I assume you added the shocks to the axle yourself? Do you have a build thread on your trailer somewhere?
  20. HenryJ
    HenryJ BLT Offroad
    155
    Jul 8, 2011
