Grease lift system
Discussion in 'Lift Systems' started by Whopper14, Aug 8, 2018.
  1. Whopper14
    Whopper14 Member
    42
    Jun 20, 2017
    Holland Mi
    Does it matter if top is up or down to add grease to my goshen system?
  2. Dusty road
    Dusty road Active Member
    851
    127
    Feb 28, 2016
    Conneaut, Ohio
    Down. The lift springs need to be in the spring tubes in order to ensure that they get the grease.
  3. Whopper14
    Whopper14 Member
    42
    Jun 20, 2017
    Holland Mi
    I cannot reach my front zerc with a grease gun. It is inside the u- shaped channel of my water tank. Anyone tried shooting grease inside the front opening around cable tube? How hard is it to add a zerc I can read? No problem getting to rear zerc fitting.
  4. Dusty road
    851
    127
    Feb 28, 2016
    Conneaut, Ohio
    Would be a matter of just getting a wrench on it and turning it to where you can get the gun on it?
  5. Whopper14
    Whopper14 Member
    42
    Jun 20, 2017
    Holland Mi
    Talked to the guy at Goshen. He advised not to drill and tap in a new zerc. He said they extrude extra metal to the tube where the place the zerc. He advised me to shoot grease into the open end of the tube where the cable enters, grease ends up at the same place as the zerc. Simple solutions...
