Great roof sealant for Pop Up
Discussion in 'Roof/Floor Repair & Maintenance' started by Brice, Sep 13, 2020.
  1. Brice
    Brice New Member
    23
    Aug 31, 2020
    I was in the paint isle at Walmart and noticed a gallon of Rustoluem elastomeric roof coating. I purchased one gallon and I was able to get 5 coats on and I still have 1/4 left.
    spreads nice and dries extremely fast in low humidity. This morning I woke up and the dew was a nice bead. Tilted the pop up and water ran off.
    I was also able to get this in all the seams nicely, so less caulk now. Just thought I would share the info., at 20 bucks a gallon you can’t beat it. It also filled in some pinholes nicely.
  2. kcsa75
    5,266
    3,299
    Sep 9, 2013
    Kansas City
    Looks good. When I saw the headline on this thread I was afraid it was going to be about FlexSeal. Glad to see you didn't go down that road. ;)
    Sjm9911 and Brice like this.
  3. Arruba
    Arruba Well-Known Member Gold Supporting Member
    712
    373
    Nov 28, 2014
    Central Oregon
    It does look good. As someone about to be in the market, thanks for posting.
  4. Stephen.81
    Stephen.81 New Member
    Jul 12, 2020
    I actually used flex seal on my roof last week and it turned out great. A bit tough to spread but it gave good coverage and a nice finish. Has good reviews.
    Brice likes this.
  5. Brice
    Brice New Member
    23
    Aug 31, 2020
    Yes, I did some research before hand and a few buddies said to stay away from that. My other choice was going to be Kool Seal but this saved me a few bucks.
    time will tell!
    kcsa75 likes this.
  6. Bob Collins
    Bob Collins New Member
    Jul 19, 2020
    Did you use a roller or brush?
    Also, what is the story with Flex Seal?
  7. kcsa75
    5,266
    3,299
    Sep 9, 2013
    Kansas City
    FlexSeal doesn't hold up to the elements. Most FS products state on the label for temporary fix only, or words to that effect.
    fronsm likes this.
  8. Jason Denniston
    Jason Denniston New Member
    Apr 26, 2021
    My roof is just like yours. What did you use to tape over the centerline trim?
    Arruba likes this.
  9. Arruba
    712
    373
    Nov 28, 2014
    Central Oregon
    Looks like Eterabond. If it’s not, Eternabond will work. There are several threads on here about it. My local RV Shop has by the foot it in a couple three different widths. It’s also available by the roll. I’d guess it’s Amazonable too.
    https://www.eternabond.com/
  10. fronsm
    fronsm First time owner at 67
    84
    19
    Jul 1, 2020
    Indiana
    Is the paint on sealer used instead of caulking? Or should I caulk and then seal?
  11. Arruba
    712
    373
    Nov 28, 2014
    Central Oregon
    I would caulk then seal. Looking at the photos, the original poster looks to have laid Eternabond down over the center trim then put on the coating over the whole affair. Either approach IMHO should work. I’d have to read up on elastomeric coating sticking to Eternabond to confirm.
    If you do it let us know how it works out!
  12. BMidwest
    BMidwest New Member
    Aug 5, 2021
    What would one use for primer under this elastomeric coating? or would you just rough up the original paint with a sander and apply this right on top of it?
  13. Grandpa Don
    Grandpa Don Well-Known Member
    1,435
    1,086
    Sep 5, 2018
    Southern California
    I have been thinking about re-sealing my Viking roof for weeks now. So this thread is very informative. I would still like to know how it was applied (brush or roller), and what do you do to the surface before application? This just might be my next project for the coming weekend!
  14. firepit
    firepit Well-Known Member
    2,547
    4,009
    Feb 26, 2020
    Where did brice go?...that old Columbia brings back fond memories of mine.
