Green wire from converter box
Discussion in 'Wiring' started by Franchesca, Apr 18, 2021.
  1. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    Connect the converter green wire (DC circuit) to a brown wire on the switch. Connect the other brown switch wire to the red pump wire. Connect the black pump wire to ground.
    Even this diagram is not right, but simple to follow. The fuse should be before the switch. Your circuit fuse, feeding that green wire, is on your converter protecting that circuit.
    ChiefHart likes this.
  2. ChiefHart
    ChiefHart Member
    45
    18
    Apr 2, 2020
    Staunton, Virginia
    The second wire is the yellow wire. You can use either the yellow or the green, just put the fuse in the corresponding slot for the wire color you use. Fuse value should be close to the pump Amperage. For example if pump is 2.5-A , then use a 5-A fuse.
    Follow WrkrBee instructions that follow this post. Connect the brown switch wire to the DC power wire (either yellow or green), and the other brown wire to the pump RED wire. Connect the pump black wire to the chassis ground or the white wire. That should be all the wires involved. Good luck.
  3. Franchesca
    Franchesca Active Member
    106
    43
    Nov 2, 2020
    Massachusetts
    Thanks for the info! I am taking the camper into the repair shop in the morning to let them do it. Next time I have to replace the water pump I will take prior pictures!!!!
  4. Franchesca
    106
    43
    Nov 2, 2020
    Massachusetts
    Again thank you for all your help in this matter. I was able to get an appointment for tomorrow morning at an rv repair center. I will let them fix the problem. Next time I will take prior pictures!!!
  5. ChiefHart
    ChiefHart Member
    45
    18
    Apr 2, 2020
    Staunton, Virginia
    Let us know how it works out. Get the info from the repair persons and pass it on.
    Franchesca likes this.
