Grey water tank add on
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by Brylothrop, Apr 13, 2019.
  1. GreyFox
    GreyFox Well-Known Member
    1,787
    883
    Oct 10, 2018
    S Ontario
    This I completely agree with, if you're camping where there are no dumping facilities available then no method of off loading waste water is going to be useful
    Does your '06 Niagara not already have an underfloor grey water waste tank? Regardless, yours is a great solution if you can find the space underfloor to mount an additional tank.
  2. cabranch47
    cabranch47 Member
    78
    25
    Nov 29, 2016
    100_0874.JPG 100_0884.JPG 100_0859.JPG 100_0874.JPG 100_0884.JPG 100_0859.JPG 100_0874.JPG 100_0884.JPG 100_0859.JPG 100_0874.JPG 100_0884.JPG 100_0859.JPG I did this. Pump grey water into barrel in truck and empty at dump station.
    crackerJack and Sjm9911 like this.
  3. cabranch47
    cabranch47 Member
    78
    25
    Nov 29, 2016
    Sorry, did not mean to post all of those photos. New at this.
  4. Dingit
    Dingit Well-Known Member
    915
    437
    Mar 8, 2017
    Photos good. No apologies! :)
  5. silvermickey2002
    4,717
    503
    Sep 11, 2008
    Morris County, NJ
    That's pretty ingenious!!!
  6. CamperChrissy
    CamperChrissy Well-Known Member
    601
    315
    Nov 25, 2016
    Chicago suburbs
    I have an 06 Niagara and it does not have a gray tank. Built in black tank under the base of the toilet, 6 gallons I think. Has the outlet thing (sorry, don't know the proper name) on the outside just like a travel trailer where I can hook up to a sewer connection or dump at a dump station. Clean water tank underneath.
  7. Mogimus
    Mogimus Active Member
    482
    79
    Apr 29, 2015
    Rancho Cucamonga, CA
    Same with mine CamperChrissy. I believe the 2007 and newer models came with a grey tank.
    As for the 6 gallon black tank, yeah it also didn’t work for me LOL. With 2 adults and 2 kids, it would be full after a weekend on only nightly uses for the kids and DW while using the campground facilities during the day. I also ended up adding a 22 gal tank below the floor so now I have 28 gal and can go 6 nights of dispersed camping
  8. David Blackwell
    David Blackwell Member
    79
    44
    May 10, 2017
    San Diego, CA
    Hi cabranch47 - I agree with the above genius comment. That's a really thoughtful approach. Could I trouble you to comment on:
    - how many gallons does that tank hold?
    - once full, how long does it take to drain?
    - do you have any problems priming the pump, and if so, how do you handle that?
  9. GreyFox
    1,787
    883
    Oct 10, 2018
    S Ontario
    Your Niagara has a 9 gal black water tank that serves as the base for the flush toilet which IIRC is a Sealand.
  10. mpking
    mpking Well-Known Member
    1,297
    315
    Jun 17, 2014
    Raynham, MA
    So how does this work @GreyFox ? IE, what drives the water from the first tank into the second tank, versus it just backing up the drain? (The drain looks lower than that clear PVC pipe)
  11. GreyFox
    1,787
    883
    Oct 10, 2018
    S Ontario
    Grey water in the sink drains under the force of gravity, once the first tank fills water flows through the interconnecting tube to the second tank. For best performance it's important to drill out the threaded vent without damaging it so water will flow easily from the first tank to the second. I used this system for years with our Fleetwood Santa Fe as an alternative to dragging around a heavy wheeled tote tank.
  12. crackerJack
    crackerJack Well-Known Member
    1,155
    324
    Jan 6, 2014
    Scottsville, KY
    It’s PFM:smiley:
  13. GreyFox
    1,787
    883
    Oct 10, 2018
    S Ontario
    That works like a charm. [A]
