Grizzly Grip and Coleman AlumiTite Roof
Discussion in 'Roof/Floor Repair & Maintenance' started by mthurmon, Apr 11, 2019.
  1. mthurmon
    mthurmon New Member
    Apr 11, 2019
    Hi all! I'm thinking of coating my roof with Grizzly Grip. There are no current leaks that I'm aware of, but signs of a previous leak on the inside. I have a 2006 Fleetwood Williamsburg, with what appears to be the AlumiTite roof. There is currently eternabond tape running down both sides (apparently there used to be roof rails there) and some bad chalking. My plan is to rip off the tape and scrape off the chalk. Then redo the chalk with Lap Sealant, then put on the grizzly grip,
    Does this sound about right? Can you apply grizzly grip to alumitite roofs?
    Thanks!
  2. mthurmon
    mthurmon New Member
    Apr 11, 2019
  3. BikeNFish
    BikeNFish Well-Known Member
    2,858
    1,764
    Apr 24, 2017
    Maplewood, MN
    I don't have your answers but wanted to welcome you to the Portal. You will get answers very soon. Be patient.
  4. joet
    4,676
    916
    Welcome from the mountains of West Virginia.
    We are using Xtrm for sealing, as the MFG's have went to this. I would scrape/clean the tape off and reseal it
  5. kevinpf
    kevinpf Member
    45
    Jul 5, 2015
    Southern California
    Grizzly Grip will seal everything for a loooooong time! and it adheres to just about everything, it is a truck bed liner product.
    If you are really worried call the company they are really good people and very helpful
    good luck
  6. tzmartin
    tzmartin Well-Known Member
    918
    355
    Sep 9, 2015
    that doesn't look like my alumtite roof. Is it just another type of ABS roof? Either way grizzy grip will work.
