Gut check on Ram 1500 TV
Discussion in 'Tow Vehicles, Hitch & Towing' started by anothersmith, Jan 8, 2021.
  1. Nick81
    Nick81 New Member
    May 9, 2019
    Gulfport MS
    I dont have figures in front of me but my daily driver and TV is a 2006 Dodge Ram 1500 with 4.7. It has the tow package. Camper is a 2001 Jayco 14 SO. Tows great. I dont know gas use pulling but not that much more it seems. On road not towing is 17mgp
    In town 15. Almost dont know i am pulling camper.
  2. RonDad
    RonDad New Member
    28
    Aug 11, 2020
    North Carolina
    Once, I had a 2005 Dodge Ram 1500 with the smaller V8 engine option. I wouldn't recommend it for towing. On the MPG front, the smaller engine had to work so much harder (frequent downshifting) than the larger option, I often got worse MPG when compared to friends. I imagine you'll find the same results with the V6 vs V8 unless there's something to compensate (like Ford's ecoboost). I'm not familiar with newer RAM's solution to better MPG, but the GMC V8's will disable half the cylinders when at cruising speed. In that case, you have the power when you need it. With a V6 no-turbos, you get what you get. :)
  3. Snow
    11,266
    1,930
    Thats is the MDS system that have been on the Hemis since 2008.. They call it Eco mode.. since 2010 (I believe) they added an eco icon to the digital multifunction odometer, because other then the feel, people didn't know it was on and working..
  4. Sjm9911
    8,771
    6,159
    I found the GMC thing to be crap, its basicly there to save on MPG so they can hit the numbers needed to satisfy the goverment. I do belive thats why my truck sucked at accelerating, there was a slight delay in hitting the gas pedal and the engine responding. On a pup it wasn't a problem, with my TT it made it harder to gain speed to enter hyways. I dont have that problem anymore, the 2500 dont have to be under any emitions standerds, so hit the gas and go.
  5. SteveP
    2,005
    741
    Having driven manuals all my life that and the weakness of engine braking were the hardest things to get used to learning to drive the Silvey. It seems to shut off when you pull it down into 3rd gear so when I think I'm going to need throttle response or engine braking I typically drive in 3rd, using overdrive only when cruising. I use the shifter a lot more than I would have expected a few years ago.
  6. Fish N Farm
    Fish N Farm Well-Known Member
    544
    426
    Aug 4, 2020
    Pearland Tx
    If the payload is ok and the rest of the truck is good jump on it. A friend of mine has a copy of the truck I have 2018 4.6 F150 crew cab 3.55 gears. I joke about mine slowing down when I get on the gas then slowly gaining speed. His was about the same. He changed the rear end to a 3.73 and it runs like a rocket. The factory is going to put the highest gear they can. He claims that he gets 1 mpg better with it. I am planning on changing to the 3.73 gears and installing an Eaton electric locker. Around town a lower gear will not hurt and my highway travel will be towing or if not towing we go in the JK.
  7. jeepster04
    jeepster04 Active Member
    138
    78
    Nov 23, 2010
    NO, NOPE, dont do it. That V6 is underpowered in the smaller Jeeps that it came it. You'll have to hold it to the floor to get anywhere with a trailer like that.
    xxxapache likes this.
  8. xxxapache
    3,649
    1,745
    If you have a 2018 F150 with a V8, you have a 5.0, not a 4.6.
  9. Fish N Farm
    544
    426
    Aug 4, 2020
    Pearland Tx
    I posted that wrong The old fat finger curse it is a 20018. Sorry about that.
  10. anothersmith
    anothersmith Member
    104
    Aug 24, 2018
    I pulled the trigger on a Ram 1500 Express with the Hemi V8. Towed the PUP with it and it’s great!
    Our poor minivan can rest easy now that the truck has taken over the towing duties.
    thanks for the input all.
  11. silvermickey2002
    silvermickey2002 Morris County, NJ Gold Supporting Member
    4,826
    633
    Sep 11, 2008
    Morris County, NJ
    A few months ago we were looking at a new Ram 2500 with the Hemi. This is because we were leaning to getting a TT. We plan on going out west and a lot thru the mountains. So getting a 1500 with the V6 was out of the question! But we ended up not getting it because we saw a Class C we really liked and then we were going back and forth. So, for now, it's all on the back burner. And now I might be retiring at the end of this year, so that changes our decision making as well.
    We have driven thru Colorado thru the mountains and we tow with our 2012 Ford Explorer with our pup and passed F150's / and 1500's with V6's and they were towing TT's...By the sound of the engine as we passed them....the engines were screaming!! If you are planning on going thru mountain passes get the bigger engine! Get the V8! Why put more strain on a V6...
    That's just my opinion!!
