Hand pump faucet replacement recommendations
Discussion in 'Camper Restoration Projects' started by Canadian Campers, Aug 19, 2018.
  1. Canadian Campers
    Canadian Campers New Member
    22
    May 22, 2018
    Caledonia, Ontario, Canada
    Hi all, just back from a week out in the pup...ahhhhhh!
    I'm looking at some repairs/improvements now before our next trip and need your recommendations for repairing/replacing a hand pump faucet. The Shurflo 150-ish model we have has a very weak faucet I guess, as our 3 year old broke it and I can't find replacement parts, so it's time to replace the entire unit unless anyone here knows where to get just the faucet. Otherwise I need your recommendations for a replacement unit.
  2. megcabra
    megcabra Well-Known Member
    2,556
    645
    Aug 12, 2015
    Chapel Hill, North Carolina
    Here is my recommendation.
    Best of luck with the fix!
  3. Canadian Campers
    22
    May 22, 2018
    Thanks for the info!
  4. v1ru5879
    v1ru5879 Member
    36
    Aug 2, 2018
    We have no intentions of using a pump to get the water so I just got a cheap cold water faucet off amazon and that stays connected to the water hook up. I plan on using a fluid transfer pump for remote locations
  5. emoney
    emoney Well-Known Member
    880
    454
    Jul 7, 2018
    I don’t know that they make one that’s trustworthy at least that isn’t over the cost of a water pump and regular faucet. You can shop the Nautical stores but last time I priced one that wasn’t plastic it was outrageous. Any reason you don’t want to convert over to a pressure type faucet?
  6. SteveP
    1,821
    597
    When the pump in my old 86 crapped out I replaced it with one of these. It was a better pump than the oem, you could actually pump and wash your hands at the same time. But that was over 20 years ago so who knows about now.
  7. Canadian Campers
    22
    May 22, 2018
    SteveP thanks, this is one I've been eyeing up. Did you have the 2 or 3 way?
    emoney, I just want to be able to take water in the pup's tank. I'm not interested in a site with hook ups, it's too expensive for the little bit of luxury you get with a pup. I am considering the electric pump though as I will always have a 12 volt system working.
    Thanks for the advise guys.
  8. SteveP
    1,821
    597
    I used the two way. The three way contains a switch to activate a low flow water pump, it's not needed if you install a typical RV pressure activated pump. I did use a low flow water pump but installed a separate switch by the sink, easier to fix if the switch failed. And you can buy the 2 way faucet and a 15 amp 12 volt rocker switch cheaper than the 3 way faucet.
