Harbor Freight 3" Flood Lights?
Discussion in 'Lighting, Interior and Exterior' started by Fshrmon, Nov 7, 2019.
  1. Fshrmon
    Fshrmon Member
    42
    28
    Sep 4, 2019
    47.9790° N, 122.2021° W
    Greetings.
    I'm kicking around installing one and maybe two of the Roadshock 3" LED Flood lights from Harbor Freight on the Pup frame. I'd like to put one up on the front so when I roll into a campsite in the evening I can light up the tongue area to make it easier to see when I'm unhooking. Also, thinking of running wires underneath the Pup to the back and installing a second one on the rear bumper of the Pup for some additional lighting. Seems like it would be a pretty simple install with direct wiring to the battery. I'm working through the idea with where I would install the throw switch.
    https://www.harborfreight.com/3-in-led-flood-light-64322.html?_br_psugg_q=roadshock
    Anyone do this? or also thinking of doing it? Is there something I'm missing as to why this might not be a good idea?
    I'm just researching and investigating at this point.
    Cheers,
    Fshrmon
  2. BikeNFish
    BikeNFish Well-Known Member
    3,492
    2,355
    Apr 24, 2017
    Maplewood, MN
    My first thought is that flood lights may be unwelcome at campsites to other campers.
    THESE are cheaper and have magnets on the back of them to stick anywhere on the frame. I have about a dozen of them and use them inside the pup and out. They are amazingly bright and HF has free coupons for them all the time.
    We hang them on the Shepard hooks on the bunk ends.
    Darkbun, Sjm9911, Raycfe and 2 others like this.
  3. kcsa75
    kcsa75 Well-Known Member
    4,105
    2,118
    Sep 9, 2013
    Kansas City
    Do these lights put out enough light to be useful backing up?
    Our last couple trips this fall we have arrived at the campground after dark and I was thinking of putting a couple small LEDs underneath and on the back it the TT.
    Econ likes this.
  4. Econ
    Econ Well-Known Member
    790
    388
    Aug 18, 2019
    Deep South
    Please let me hijack and add on to this thread. I drove 12 hours and tried to back up my driveway with the pathetic Aliner back up lights. Found found the socket on one was bad. The other had a bulb from the 1930's. I'm looking for backup lights that will melt anything within 20' feet. People would rather be anoid by backup lights than me running over their tent <GG>.At my age its hard to see 35'+ feet behind you going up a curvy driveway.
  5. nineoaks2004
    8,213
    3,676
    Dukes, Fl
    I have 2 of those you attached picture of on the front of my tractor, they are really bright, maybe
    a little too bright for what you are considering and would probably have the CG neighbors
    complaining. Get a couple that BikeNFish recommended and try them, they are cheap and sometimes free at HF. Good Lick and happy Camping
    Fshrmon likes this.
  6. Fshrmon
    Fshrmon Member
    42
    28
    Sep 4, 2019
    Thanks Everyone.
    I'm digging the idea of using those blue HF magnetic lights. I've already got some of them around the house and in my camping gear. Didn't even think to use them and no wiring needed, which I like that!
    I'll table the flood light idea and give those blue lights a go. I also don't want to upset other's experiences in the CG. I don't want to be like Cousin Eddie that's for sure.
    Cheers,
    Fshrmon
    BikeNFish likes this.
  7. Snow
    10,957
    1,618
    I mounted a set of old foglights from one of our past cars on the rear bumper of our TT.. wired the lights up to the trailer battery, the relay and the switch actually both sit loose up in the tongue area below the propane tanks (under the tank cover) .
  8. BikeNFish
    3,492
    2,355
    Apr 24, 2017
    Maplewood, MN
    I have never tried it, but i would imagine that you could attach as many to the bumper as needed. If one doesn't work, add more! They're cheap.
  9. Toedtoes
    Toedtoes Well-Known Member
    2,342
    2,187
    May 28, 2018
    I agree about bright floodlights being annoying to other campers.
    Similar to the ones BikenFish linked, I have a couple of these: https://www.harborfreight.com/rotating-magnetic-led-worklight-63766.html
    I like them because I can set them on the ground on either side of the parking pad and use the lights to guide me in. I just angle them towards the height of the tires and when the tires are lit up, I'm far enough back. They are easy to attach to the hitch also.
  10. Anthony Hitchings
    1,538
    795
    Mar 2, 2019
    more trouble than its worth - just grab your trusty head-lamp. In a similar vein I just relegated my blinding Ryobi 18V LED work lamp to storage - light was too bright and harsh - headlamp worked better for house and car projects.
  11. jeeper88
    jeeper88 Let's go Camping and Jeepin
    900
    70
    Apr 24, 2011
    Ocala,FL
    I have two LED 4" flood lites on my rear bumper wired to my back up lites. Works great. photo(4).JPG
    kcsa75 and Fshrmon like this.
