Hardcrank... We popped her up FINALLY
Discussion in 'Lift Systems' started by kittytickle, Mar 12, 2007.
  1. kittytickle
    kittytickle New Member
    44
    Feb 1, 2007
    Finally... After a nice 60 degree weekend we got her up.... I am so stoaked. I took a bunch of camping stuff out of storage and started loading her up. The kids are so excited and can hardly wait to take her out. I am still likely going to have the electric winch on it. Since the car accident I just don't have the strenght that I had. The hubby pulled up and I did the cranking. Thanks for everyone's suggestions I think that maybe it was just way to cold for it. Now all that need is to have a hitch put on the Ford Ranger I bought this weekend and a nice weekend to take her out and we will be smelling canvas and hopefully not getting wet. Talk to you all later.
  2. finfin
    finfin New Member
    Apr 25, 2007
    Can you really lift a pup roof with a drilldriver? Mine seems hard to crank I figured it would be to much torque for a drill driver. It seems like it would need to be geared way down.
  3. John L
    John L New Member
    520
    Aug 15, 2006
    Vermont
    I bought a Sears 19.5 volt cordless drill thinking it would do the job but it didn't.
    Then this past weekend I crawled under the PU took the plate of the cranking mechanism and greased the long screw shaft with a good bearing grease. Then I greased the top of the plate where the pulley runs and I used silicone spray on the pulleys. I tried the drill for the heck of it and it worked great.
    I made my drill crank by buying a cheap 1/2 inch socket drive shaft, cut one end off and ground it down to have 4 flat sides until it fit my drill bit. Then I bought a cheap 1/2 inch drive, deep socket to fit the whole in the lift mechanism. I then used my right angle grinder to cut a slot in the end if the socket to fit the pin in the crank shaft. It all took about 15 minutes and cost about $5 and it works great.
    John & Kitty (Empty Nesters)<img src=../Images/icons/icon_smile_camping.gif border=0 align=middle>
    '02 Coleman Cottonwood <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle>
    http://community.webshots.com/user/VTWoody
    '97 Silverado X-Cab Stepside <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle>
  4. kittytickle
    44
    Feb 1, 2007
    That is exactly what we ended up doing. we are using a pulley system to pop her up. It works great as well.
    Rebecca
    Are we camping yet???
  5. finfin
    finfin New Member
    Apr 25, 2007
    John L, has made a very good point about lubing the system. It still seems that it might turn it a little to fast. I'm going to give it a try though.
