Has anyone tried replacing stabilizing jacks with leveling jacks?
Discussion in 'A-Frame PopUps' started by cindy_k, Sep 3, 2021.
  1. Ed Llorca
    Ed Llorca Member
    37
    Jul 16, 2018
  2. RonDad
    RonDad Active Member
    115
    117
    Aug 11, 2020
    North Carolina
    Doesn’t seem to carry the same structural risk as level via the frame’s corners. But I couldn’t make the recommendation with as many other options as have been listed- ones that don’t require you to get down underneath to get the jacks on safe lift points.
    Two of these other options you drive onto. Who’s doing the work?…the tow vehicle.
  3. Sjm9911
    10,626
    8,008
    Yea, rhey also say not to jack by the axel, could be a reason for that or not. Also , you have to consider how low your system will be. Im sure there is a way to do it. But i for one wouldn't want to be the test subject and 2 would fint it easier to use blocks. But if you have the time know how and money, go for it. Let us know how it turns out.
    RonDad likes this.
  4. Ladiesman
    Ladiesman Well-Known Member
    755
    541
    Feb 6, 2018
    I agree the Andersons are the easiest and best way to level. I would not
    use anything else. There is no stacking blocks guessing how many you need. Roll up on it till level kick the chock under and done. Simple
    theseus and DiamondGirl like this.
  5. BikeNFish
    BikeNFish Well-Known Member
    4,138
    3,121
    Apr 24, 2017
    Maplewood, MN
    Leveling side to side using any other method than leveling from the tires is a bad idea. My manufacturer (Flagstaff) even cautions on placing jacks on the axle for any extended period of time other than performing maintenance or changing a flat tire. Leveling jacks on the axel would fall under the same category. Some manufacturers do not recommend using the axel at all to lift and have special plates or reinforced bars to use when lifting a camper.
    Besides, the OP was talking about replacing their stabilization jacks with leveling jacks. Your project is completely different, but none the less, not recommended by most manufacturers if not all.
  6. cindy_k
    cindy_k Member
    50
    45
    May 9, 2021
    Florida
    Thank you everyone!
    We are going to look at getting one of those BAL Tire levelers instead.
    This board is great for all the information.
    BikeNFish likes this.
  7. 1380ken
    1380ken Well-Known Member
    2,759
    1,175
    Nov 7, 2013
    Mass
    The frame will twist, the sky will fall.
  8. Cydnew
    Cydnew New Member
    Jun 22, 2021
    The sky might not fall, but your walls might detach from your cabinets, your door won't fit correctly, and your pop up itself will start to feel like it will fall apart as it becomes less stable.
    Signs indicate that the previous owners did this to ours, and I'm still fixing things. It's fixable, but annoying.
  9. Patrick w
    Patrick w Active Member
    309
    131
    Aug 13, 2021
    I had to order from some random rvpartscountry.com as apparently nobody has bal levelers in stock.
    I ordered the camco ones and while sturdy, is not my favorite.
    I've watched the bal levers in videos , and safe to say it offers the ability to drop the trailer where you want and worry about leveling later. With every other option, leveling is something you must do first. While it can be a 1 person job, unless you know when your level, there is a lot of getting in and out until you get it right.
  10. Tait
    Tait Active Member
    106
    99
    May 1, 2020
    I use the BAL leveler, and I'm very happy with it. Going to add the PVC cover for the greasy screw per previous comment in this thread...
