Heat and AC fan question
Discussion in 'Heating / Cooling Systems' started by Michael Boyer, Nov 8, 2020.
  1. Michael Boyer
    Michael Boyer New Member
    Mar 14, 2019
    I am planning on doing some cold/cool weather camping, I will be using 2 electric heaters to heat my PUP, can/should I run the AC in fan only mode to help distribute the warm air around the PUP? Thanks in advance.
  2. Anthony Hitchings
    1,776
    935
    Mar 2, 2019
    if the AC fan is quiet then run it, else perhaps get a quieter USB fan to move air around
  3. Sjm9911
    7,889
    5,210
    You probably will not need it. Those ellectric heaters will do fine by themselves.
    xxxapache likes this.
  4. tombiasi
    6,088
    1,623
    The A/C fan may pull air in from the outside. Check that.
  5. Sneezer
    2,393
    1,234
    Two electric heaters plus the overhead fan may trip the pole. Most campgrounds I have been to will trip when using two heaters on just the regular plug while tent camping.
    I never run the overhead when using the heater and it warms up nicely.
  6. Michael Boyer
    Mar 14, 2019
    Thanks for all the replies, I will probably not run it then.
  7. rsdata
    rsdata Active Member Gold Supporting Member
    231
    54
    Oct 3, 2011
    N. KY
    depending on the weather 1 heater may be all you need, again depending on size and wattage, and by all means a cheap 20 inch box fan or something smaller will circulate the warm air off the ceiling, I normally point the fan toward the ceiling to move the warmed air around...
    I also use a Mr. Heater Buddy heater powered by propane if boondocking.
  8. Sjm9911
    7,889
    5,210
    I used my light fan things to move air. Not super powerful, but enough to direct heat/ac to the bunkends. Ill agree, depending on the weather 1 heater worked for me. But it wasnt super cold out.
