Heated Mattress + Foam Tiles
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by 123Ashley, Jan 13, 2021.
  1. 123Ashley
    123Ashley Member
    40
    Aug 28, 2020
    Does anyone with heated mattresses also use the foam tiles underneath the mattress? I go back and forth about whether or not it is a good/safe idea.
  2. CajunMan
    CajunMan Active Member
    101
    71
    Mar 7, 2020
    I have this setup but haven't used it yet so I'm following! I wouldn't think there would be a problem though the wires are internal
  3. Sneezer
    2,436
    1,279
    I have foam tiles and a heated mattress pad. Works fine for me. I especially like being able to warm one side of the bunk so I can kick a leg out to the cooler side if I get too warm at night (solo camper).
    MD Chef likes this.
  4. Tom Jordan
    Tom Jordan Active Member
    162
    110
    Jun 3, 2019
    ArkLaTex
    We have memory foam under our mattress. We have had no problems using the heated mattress on that. But heat it up then turn it off before bed.
  5. jonkquil
    jonkquil Active Member Gold Supporting Member
    681
    174
    Jul 20, 2009
    I have foam tiles and a heated mattress. From my experience my mattress doesn't get hot enough to warm up my foam tile much, but that could mean that my heated mattress doesn't work fully. If you are worried about it, you could periodically check the temp under the mattress and if it feels hot, turn it off and don't sleep with it on.
