heated mattress pad
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by motor12, Feb 2, 2008.
  1. motor12
    motor12 New Member
    Mar 26, 2007
    do you put the pad on top of the mattress then a sheet or do you put the pad under the foam mattress? not sure about sleeping directly on the pad.
  2. Tikker
    Tikker Member
    313
    May 9, 2007
    Humboldt, Saskatchewan
    I'd think you'd put it on the mattress, under the sheet
    I've got a bed warmer for the bed at home (not in the pup!) and that's how it's installed
  3. Yellowkayak
    2,198
    Mar 13, 2007
    We use a dual control heating blanket between the sheet and the thick comforter to hold the heat in.
    Wichita Falls, TX
    USAF Retired
