Heated mattress
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by Mattda, Oct 4, 2019.
  1. Mattda
    Mattda Member
    48
    Sep 4, 2018
    2010 Flagstaff with heated mattress. Last year the heated mattresses worked fine. I took them out of the camper when I winterized it to keep them out of the elements. Now neither mattress works. Is there some kind of fuse or safety reset I’m not aware of?
  2. tombiasi
    5,850
    1,415
    If neither one works I would first check the power source.
  3. BikeNFish
    BikeNFish Well-Known Member
    3,410
    2,304
    Apr 24, 2017
    Maplewood, MN
    First thing I would check was to make sure the outlets are working.
  4. Mattda
    Mattda Member
    48
    Sep 4, 2018
    The controllers light up,so they are getting power. Just weird that both of them aren’t working.
  5. BikeNFish
    3,410
    2,304
    Apr 24, 2017
    Maplewood, MN
    I know that my plugs are VERY tight and take some effort to plug the controller into the mattress. When I used mine a few weeks ago, I really had to work to get them to make a good connection. Are you sure you have a good connection to the mattress plugs??
  6. Mattda
    Mattda Member
    48
    Sep 4, 2018
    Yes it’s definitely a tight connection. I couldn’t possibly push them in any tighter.
  7. WVhillbilly
    WVhillbilly Well-Known Member
    841
    624
    Jun 6, 2018
    WV
    How did you store them?
    Did they get rolled or folded?
    We just leave ours in place.
  8. Mattda
    Mattda Member
    48
    Sep 4, 2018
    They didn’t get rolled up but folded slightly to get thru the door. We’re camping now. I have 1 plugged in for quit awhile. It seems like it’s only hot near the plug. We’ll see how it feels when it cools down tonight. Can something happen if they get folded? I don’t think I needed to fold it that much to get thru the door.
  9. WVhillbilly
    841
    624
    Jun 6, 2018
    WV
    Sounds like the heating coils inside the mattress are broken.
    If it's hot near the plug, but nowhere else, it's not getting power through all of the heat grid.
    I wouldn't keep trying to use it, and I'd unplug it.
    There is a chance it could cause a fire.
  10. Mattda
    Mattda Member
    48
    Sep 4, 2018
    Thanks, I unplugged them. Unfortunately I think your right about the grids. Dumb of me to remove them for the winter. Oh well nothing I can do about it now.
  11. Sneezer
    1,934
    826
    I don't have heated mattresses, but I did pick up a heated mattress pad 2 years ago. I just throw that on under the regular mattress cover, works fine. I got mine on clearance after winter, so keep an eye out.
