Heater during storage
Discussion in 'Miscellaneous Repairs & Maintenance' started by Aaol1, Mar 6, 2020.
Tags:
  1. Aaol1
    Aaol1 New Member
    Nov 9, 2019
    Just got a 2008 fleetwood bayside! Love it so far, and keeping it outside stored (uncovered) until may ish. We live in Victoria bc, very humid
    Wondering about moisture control, previous owner would have a small heater plugged inside, definitely not super hot but warm enough to get the moisture out. I've read about risk of creating condensation by introducing heat, and lots of people just use moisture collecting stuff
    Anyways, thoughts on a small heater set to low, just enough to get moisture out?
  2. tombiasi
    5,826
    1,404
    If you use a heater you need ventilation or no moisture will leave.
  3. Aaol1
    Aaol1 New Member
    Nov 9, 2019
    Right but no moisture would get in in the first place right? And also seeing as the trailer isn't obviously airtight, seems like there's always a way for the heat/moisture to get out, thoughts?
  4. generok
    generok Well-Known Member
    2,698
    940
    Feb 7, 2013
    Anchorage, AK
    I would not waste energy to heat a stored RV of any kind. Throw some Damp Rid units in there and sleep soundly at night.
    gladecreekwy, kcsa75 and neighbormike like this.
  5. Aaol1
    Aaol1 New Member
    Nov 9, 2019
    Alright yea, do you think that would be sufficient for somewhere like pacific northwest?
  6. Aaol1
    Aaol1 New Member
    Nov 9, 2019
    And wouldn't the pods absorb moisture from outside, since the trailer isn't obviously airtight?
    xxxapache likes this.
  7. Snow
    10,659
    1,403
    Live in Ontario so much dryer then B.C, all I did with our pup was toss in a few containers of a damp rid type product from the dollar store and close up the trailer, a few years I would use 2 inch foil tape and put it over all the seams, door to body, roof to body and side storage hatches to keep blowing snow out.. With the TT, I toss in the same damp rid pods and close the door.. usually once a month I open the door and speak inside, in another couple weeks I'll crack one of the roof vents a bit, as the temps warm up so air can start circulating..
  8. WrkrBee
    WrkrBee Well-Known Member
    3,513
    1,478
    Don't know about a popup, but an Aliner is not air tight at all. Key is air flow to deal with moisture. A 40 watt bulb, in a drop light, in the camper will probably do about the same. Just a hot spot to create a little thermal current. I keep one in my boat, under the engine. I've seen boats sealed tight over winter, come spring they are covered inside with mildew, due to the moisture in the bilge that could not escape.
  9. generok
    2,698
    940
    Feb 7, 2013
    Anchorage, AK
    If adding something to the rig in storage gives you peace of mind, then do it. Is it needed? My opinion is no, not really based on my experience in Alaska. YMMV.
  10. tombiasi
    5,826
    1,404
    The moisture is already in there. Use the heater to dry it out and then place some silica gel in there.
  11. GrueMaster
    GrueMaster Active Member
    184
    60
    May 22, 2013
    Saint Helens, Oregon
    I live in the Portland, Oregon area and used to store my pup in Bellingham, Washington at my parents house, neither locations are sheltered. Never had a mildew problem inside. Just pop it up on a nice weekend prior to your first campout and do a little spring cleaning.
    1. Wash the exterior (same as you would a car or boat) while closed
    2. Pop it up and open up for air flow (stale air)
    3. Flush the water lines
    4. Wipe down the canvas
    5. Wipe the counters
    6. Wash the linens
    7. Wash the dishes and cookware
    8. Sweep and mop the floor
    9. Take inventory and stock non-perishables for the season
    Should be good to go. Enjoy your first camping trip of the season.
    Usually, the reason that mildew builds up is that it needs both moisture and heat. Here in the Pacific North Wet, we have one or the other during winter (thanks to global climate change). As long as there is decent airflow (ie, you aren't wrapping it in a tarp), when the sun comes out, it will warm up the pup enough to dry out any minor moisture that may build up. If you do have excessive moisture inside, then you have other issues (leaky roof).
  12. Aaol1
    Aaol1 New Member
    Nov 9, 2019
    And. Do
    Hmm interesting, I'm just so paranoid about moisture and mold, especially with so much canvas material. Alright thank you all for your feedback, definitely something to consider!
  13. Mike76
    Mike76 Member
    49
    Mar 20, 2017
    Live in the Okanagan so again drier than Victoria, but I don't do anything for moisture and it's been fine for us. There's enough airflow or moisture isn't getting in...and mine gets covered in snow all winter. I'd do damprid stuff if I was worried though, way before using a heater which has a significant fire risk a big waste of electricity.
  14. jeeper88
    jeeper88 Let's go Camping and Jeepin
    888
    64
    Apr 24, 2011
    Ocala,FL
    I use Damp Rid anytime I close it up. I use two large tubs and they will last a long time, 4 to 5 months. Have never had mold or any dampness. Rual King has them for $8. Great price.
    Senft78 likes this.
