Height of popup with roof fully raised
Discussion in 'First Time & New Camper Owners' started by easyed, Sep 10, 2019.
  1. easyed
    easyed New Member
    Sep 10, 2019
    Denver
    I'm looking for a popup with a 12' box that will fit under a 91" deck fully raised. Any suggestions?
  2. 1380ken
    1380ken Well-Known Member
    2,209
    650
    Nov 7, 2013
    Mass
    You could take off the tires. It might fit
    Ladiesman likes this.
  3. jmkay1
    5,290
    2,111
    My popup with its roof fully raised is I want to say is about 8.5’ high from the ground. Now my old Jayco sat much lower to the ground than most popups today, it may have fit. With that said you can raise the roof as high as It can go and still be able to pull the bunks out if you need it to air dry, but you won’t be able to put the shepherd poles in. That way you can still walk inside etc.
  4. GreyFox
    GreyFox Well-Known Member
    2,026
    1,011
    Oct 10, 2018
    S Ontario
    What I'm sure everyone is asking - why? [?:~{]
  5. Wrenchgear
    3,427
    684
    Aug 5, 2010
    5 Star Eagle Camper
    Mine is set up out in the driveway right now, so I ran out there and measured it for you. 102 inches high, plus the roof vent up on top that is probably 3-4 inches more. No A/C on mine. 2002 Rockwood 1910, 10 ft box with a 2 ft storage on the front.
  6. GreyFox
    2,026
    1,011
    Oct 10, 2018
    S Ontario
    Your Utah is spec'd at 8'3" (99") plus the height of anything else that may be on the roof - racks, vent, A/C, etc, and typical of most popups these days.
  7. Dingit
    Dingit Well-Known Member
    959
    470
    Mar 8, 2017
    I did an axle flip so my popup can no longer be fully popped in the garage. Sooooo, I pop it up as far as it goes. (It takes a second person on a step stool to yell "STOP!" when raising the roof.) Can't install the door, of course, but I can put up the bathroom walls which I'm sure would hold up a collapsed roof long enough for me to get out should it all fail.
    If you want to keep it popped up and use it for extended periods, this wouldn't work. But if you just want to be able to pop it up and work on it for a few days at a time, no biggie I should think. (I suppose you could rig up a curtain with some velcro to serve as a door...)
    My garage is 9 ft. I have a highwall but no AC. Popup fit in its stock configuration.
  8. easyed
    easyed New Member
    Sep 10, 2019
    Denver
  9. easyed
    easyed New Member
    Sep 10, 2019
    Denver
    (Continued) It looks like the traveling height of the Colemans went from 47" in 1995 to 54" in 1996 and I assumed the pre 1996 models were 7" lower when fully raised as well as when closed. The 1996 models were 100" high when open but I can't find the specs on a 1995. In particular I'm looking at a Stoney Creek as a possibility. Do you know how high it is fully raised?
    Thanks,
    Burt
  10. 1380ken
    2,209
    650
    Nov 7, 2013
    Mass
    You could mod the camper so the height is less. Mod the door and shorten the canvas.
  11. easyed
    easyed New Member
    Sep 10, 2019
    Denver
    Can you partially extend the roof up and it will stay up OK?
  12. GreyFox
    2,026
    1,011
    Oct 10, 2018
    S Ontario
    If you're talking Coleman / Fleetwood then yes, the lift system is self braking and can be paused at any height. That of course assumes the lift system is working properly. ;)
  13. easyed
    easyed New Member
    Sep 10, 2019
    Denver
    Good to know. I talked with someone today about a 1992 Coleman Sequoia and he said fully open it measures 92" to the top of the roof. I assume the Stoney Creek in 1995 would be the same height unless someone knows differently
  14. Ladiesman
    Ladiesman Active Member
    268
    147
    Feb 6, 2018
    Why not, Take the tires off and set the frame on some blocks. Would be super solid.
