Hodorgoestomordor
New Member
- Aug 31, 2021
- 3
I was attaching a new replacement filler hose and snapped off the water tank inlet. How do I repair this?
I didn't see a photo of the broken part. Let's see it.
Well without seeing an actual photo of the broken part, I can only assume that both pieces are the clear plastic. If that's the case, you can pull the tank out and take it to a shop that does Plastic welding. There are many post on this forum about plastic welding. Do a search and you can get more information.I don't have a picture of it... it's essentially the inlet spot where the 1-3/8" fill hose attaches to the fresh water tank.
