HELP...CLEANING POP UP?
Discussion in 'First Time & New Camper Owners' started by lovetocamp2010, Jun 5, 2011.
  1. lovetocamp2010
    lovetocamp2010 New Member
    64
    Mar 25, 2011
    JUST PICKED UP THE POP UP?
    WINDOWS NEED TO BE CLEANED - WHAT DO I USE?
    CURTAINS A LITTLE YUCKY - CAN I WASH THEM IN THE WASHING MACHINE AND DRY THEM?
    RAILS SEEM A LITTLE TIGHTER WHEN WE FIRST LOOKED AT IT - JUST ADD WD40?
  2. BaylorWaylor
    BaylorWaylor Member
    486
    May 27, 2009
    Whitehouse, Tennessee
    wash the curtains in the washing machine, we hang dry ours, don't use wd-40, use silicone spray for the slides, make sure to hold a piece of cardboard behind it to keep it off the canvas. wd-40 attracts dirt.
  3. TX_F2
    TX_F2 New Member
    1,041
    Mar 30, 2008
    Texas
    For cleaning the plastic windows just use a damp clean soft cloth, if you use cleaning products such as Windex or Fantastic they can sometimes leave a film.
  4. Mountdream
    Mountdream New Member
    129
    Dec 27, 2010
    Question about the plastic window—ours has a bit of grease. What do you use to take it off?
  5. Dusty82
    Dusty82 Active Member
    3,513
    Jun 23, 2008
    Northern Nevada
    The vinyl windows in most pop-ups is the same material used in automotive convertible tops. Anything that has ammonia or alcohol in it will eventually turn them yellow and make them brittle. Basically any car wash soap that specifically lists itself as being safe for convertible tops will work just fine. I mix up a bit of the soap with water in a trigger spray bottle and spray the windows with it, then rub them with a soft cloth. I rinse them with a wet cloth (just tap water) and dry towel. I use Blue Coral brand, but that's just me - any brand that's safe for convertible tops will work fine. It'll also take off grease fairly well, but you might need to clean the greasy window a couple of times to get all the grease off.
  6. Popsrock
    Popsrock New Member
    29
    May 24, 2011
    BAYLOR WAYLOR - thank for the tip on cleaning the curtains...I got them down but was stumped about throwing them in the washer. Moving ahead with interior "whole-house" cleaning. THANKS for taking the time to respond to inquiry.
  7. Canadienne
    Canadienne New Member
    Aug 6, 2007
    I would use Good old vinegar and water to clean vinyl windows. It's safe,cheap,cuts grease and leaves no streaks. [2C]
  8. Mountdream
    129
    Dec 27, 2010
    We use vinegar for everything around the house. It's ok to use on the plastic windows?
  9. Hyperterex
    Hyperterex Active Member
    1,023
    Jan 1, 2010
    I say start with some mild soap and water and work up from there. Its amazing how good it will work with a little elbow grease. :)
  10. tvketchum
    tvketchum New Member
    98
    Mar 30, 2011
    We have never had a problem with Murphy's Oil Soap. Takes the dirt, bird doo, pine pitch, and road grime off very well, does not attack canvas or vinyl windows, and does not cause haze or films or yellowing.
  11. KateTheKamper
    KateTheKamper Member
    505
    Apr 1, 2009
    Michigan
    Murphy Oil Soap is my fave, too. Good stuff!
  12. Popsrock
    Popsrock New Member
    29
    May 24, 2011
    Hillbilly Housewife recently had a recipe for a cleaning solution that I finally made and tried; think it's the best all-around cleaner I have ever used and is infinitely less expensive that the brandds. Solution: in a regular sized spray bottle, fill one fourth of the bottle with vinegar, give it two good squirts of Dawn (NOTE: look for the dark blue "original" detergent), then fill the bottle to the top with water. I use it in the tub and shower and now on hard surfaces in my pup including the floor, and it produces great results. Don't be put off by the vinegar smell, it dissipates within 10-15 minutes.
    I also make my own laundry detergent and fabric softner for pennies a load. Let me know if anyone is interested in that recipe. Take care and keep camping.
  13. IV Nurse
    IV Nurse New Member
    163
    Jul 4, 2007
    Maryland
    Yes, please share the recipes. Are they safe for front-loading HE machines?
  14. mesuezee
    mesuezee New Member
    39
    Jun 13, 2011
    newbie question- when you wash all the curtains, do they detach from their clips. We are getting our camper in about 2 weeks and I would like to do a spring cleaning. Do the curtains come off easy. I will have a '99 fleetwood nevada. Thanks!
  15. BaylorWaylor
    BaylorWaylor Member
    486
    May 27, 2009
    The curtains are easy to come off, they pretty much just slide out. If a clip does come off you can just sew them back on real easy.
  16. mesuezee
    mesuezee New Member
    39
    Jun 13, 2011
    cool thank you!
  17. tess1
    tess1 New Member
    Jun 11, 2011
    I am a big fan of Dawn for anything greasy that needs something gentle. Peanut butter in my child's hair. Desitin smeared over her younger sister. The entire jar of vasoline smushed into my walls.
    I used to work for an oil company and we used it to clean crude oil off birds during spills. Birds are very fragile really, so goes to show how delicate it is. And crude is definitley heavier than any grease you'll pick up around the house. Plus, you only need a few drops.
    Tess
