Help External lift arm “spring” replacement
Discussion in 'Lift Systems' started by Michael W, Aug 8, 2018.
  1. Michael W
    Michael W New Member
    Aug 6, 2018
    Hi,all
    I have a 1982 Shasta 165 with external lift arms. I just ordered new Springs for the lift arms and I have a good idea oh how to remove the complete arm assembly.
    I need help with how to remove the spring from inside the lift arms!!! I’ve been doing a lot of searching and can’t find a diagram or exploded view of how the lift arm itself is assembled.
    Can anyone weigh in on this!? I’d really like some insight on how to do this before diving into it.
    Thanks in advance!!!!
  2. Michael W
    Aug 6, 2018
    5581571D-8352-45A1-A8DB-6069F2FCCFD4.jpeg C95E6C3D-7A26-48F7-9A4B-FA3F7F31D8EE.jpeg AD39D326-790A-4408-8A8B-05A2B351A285.jpeg 6CE4CBF5-09B8-4D66-9CE0-4F7B274480FA.jpeg 8F42CA5E-3AE7-4606-B0E2-E60E68E6188A.jpeg Well since apperantly I can’t find anyone who has done this before,much less anyone that knows what an external lift arm is. [::)]
    So first you have to remove the arms. “YOU MIST DO THIS WITH THE CAMPER POPPED UP!” Springs have the least amount of tension when the arms are fully extended.
    Get a piece of timber or 2x4 to brace the top on the corner your removing the arms. I cut a piece slightly taller than the bottom of the roof and used the tounge jack to lower the corner of the roof onto the timber.
    I removed the side handle looking brace that holds the arms in place.
    Then remove the hardware that holds the arm on. I then had to grab the spring inside the lower arm where it attaches at the bottom mounting bolt. Pull on the spring to remove the leftover tension and slide,wiggle,and pry the arm off the mount points.
    After removing the arm you will have to remove the pin that holds the two legs together. Then separate the arms and replace the spring. Reconnect arms and replace the pin you removed. And reinstall back onto camper.
    The pics above show you the pin you have to remove to separate arms. I will post more pics tomorrow.
    ken Barlow and megcabra like this.
  3. Michael W
    Aug 6, 2018
    36CC9034-0661-46A9-936F-BAE42A03787A.jpeg 24FDA86E-84A9-4403-977F-80D946379EAA.jpeg 595C2C8C-70CB-468F-8A59-4E5BE1AA45C3.jpeg 8B18622F-99EA-43F7-BFDD-7226B8491448.jpeg 8B67837F-9E1C-48CF-AA5E-10C257E490A8.jpeg 42E281DC-80AC-4A8B-9360-065B3227E0A9.jpeg 3FAB050D-283B-48EE-A72A-8B31B93210AB.jpeg
    megcabra likes this.
  4. Michael W
    Aug 6, 2018
    By the way, this helped a ton!!!! So much easier to pop up the camper!! Totally worth it.
  5. Rachel Herrera
    Rachel Herrera New Member
    Aug 21, 2018
    So... on our pop up there are eye bolts that attach the spring to the frame. We were thinking we would remove the eyebolts and replace the springs that way. I havent ordered the springs yet. It is difficuly to raise and comes down dangerously fast.
  6. Michael W
    Aug 6, 2018
    974515A3-470F-4F8B-B2DD-426B327E9F02.jpeg 071ECDF6-4E16-418C-BBA2-C731E253B1AD.jpeg
    Our ms was extremely heavy, me and the wife could barely pick it up and it was very hard to lower. Really needed 4 people on each side. After the springs I feel confident my wife could lift it up herself if necessary.
    Can you post pictures of how the springs attach?
    My springs are inside the arms. There are bolts that stick out of the camper one on top (roof) and one on bottom (box) and go through the arms and a nut on the other side to hold the arms on. The spring loops around the lower bolt inside the arm.
  7. Smileybella
    Smileybella New Member
    Nov 12, 2018
    Hi, I have been following your post. We have an old 1983 au wagon with external arms. The arms don’t seem stable and two have broken.
    Do you know where I can get new ones. Seems to be similar to the ones you have (or I think they can work).
    Thanks
  8. Smileybella
    Nov 12, 2018
    Sunwagon
  9. Jessica Duggan
    Jessica Duggan New Member
    Wednesday
    I am really happy that I found your post. I’ve been looking to do the same thing with my camper. At the moment the springs don’t work(not sure they are still in there) so I have to lift it every time I want to pop it up. Next project will be replacing the springs. I’ve been putting it off because I didn’t want to have to replace the whole arm. Thanks so much for the information.
