Help! I don't know how to clean this!
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by gketchup, Apr 8, 2016.
  1. gketchup
    gketchup Member
    259
    Feb 23, 2012
    We camped for 10 days in gorgeous weather. We had the ceiling vent open and the fan on at night. It wasn't until we set up on our next trip that I noticed the mess it made. I'm thinking this is spot from camp fires. I'm in the middle of painting and making new curtains. It would be awful to do all this work to have a major blemish right as you walk in the door.
  2. gketchup
    gketchup Member
    259
    Feb 23, 2012
    Here's a picture. [​IMG]
  3. gketchup
    gketchup Member
    259
    Feb 23, 2012
    Soot, not spot.
  4. chambo
    chambo Active Member
    358
    114
    Apr 27, 2015
    Southern California
    Are you sure it's not mildew? That's a lot of soot. I've used the bass pro shops mildew remover and it worked very well. Even on stuff that wasn't mildew. It's bleach based, so be careful with what it comes in contact with.
    Sent from my SM-G900V using Tapatalk
  5. VulcanGuy
    VulcanGuy New Member
    36
    Feb 1, 2016
    Our awning bag had some stains that looked like that . I used some cheap spray foaming bathroom cleaner from dollar store .It took it right off !
  6. gketchup
    gketchup Member
    259
    Feb 23, 2012
    Well, I worked on it some this weekend, in between projects. I used a little dish soap in water with a rag. It didn't do too bad. I'm going to try it again this week. I also picked up a lint shaver and took care of the fuzzies. It seems better than before, but still needs work. [​IMG]
  7. nhcaveman
    nhcaveman Barrington, NH
    1,320
    76
    Mar 25, 2009
    New Hampshire
    We have a local RV store, place that stopped selling new campers a few years back, that now sells products, accessories, and does service.
    Last year they sold me this Star Brite here, it's about $12 but I sprayed it on waited ten or so minutes like it said, and the stain disappeared, and I then wiped it with a damp cloth. Looks great now. And it was mildew that looks just like what you're showing there.
    http://www.starbrite.com/item/mildew-stain-remover
  8. gketchup
    gketchup Member
    259
    Feb 23, 2012
    It definitely isn't mildew. When we opened it up there was black specks on the counter right below it. It may not be soot, but it isn't mildew either. I've tried a lot of things on it and it's much lighter. My eye isn't drawn immediately to it anymore either. I may have to get some Star Brite for the future though! Thanks for all of the tips!!
  9. bols2Dawall
    bols2Dawall S.W. Ontario
    1,489
    172
    May 19, 2010
    Lasalle Ontario
    It looks like it's from rubbing on aluminum tracks etc. I get the same thing
  10. bondebond
    bondebond New Member
    2,079
    19
    Aug 14, 2008
    If it is from coming into contact with aluminum, I haven't found anything yet that will remove it. If someone does, please share. I have had sections of the tenting come into contact with the aluminum rails, rub and get marks all over them. It's very frustrating to have that on an otherwise flawless vinyl and Sunbrella tenting.
  11. gketchup
    gketchup Member
    259
    Feb 23, 2012
    I don't think that's it either. It is 2/3's of the way up the wall. There was black grit on the counter. I honestly don't think it is that.
  12. silvermickey2002
    silvermickey2002 Morris County, NJ Gold Supporting Member
    4,817
    604
    Sep 11, 2008
    Morris County, NJ
    Did you try Woollite? I use that to spot clean ours.
  13. gketchup
    gketchup Member
    259
    Feb 23, 2012
    That's my next purchase. I have heard that works on stains also. Do you dilute it at all?
  14. silvermickey2002
    4,817
    604
    Sep 11, 2008
    Morris County, NJ
    Yes, I followed the directions on the bottle and used warm (not hot) water. I used an old tootbrush to rub it in. I then used cold water to rinse it off.
  15. bols2Dawall
    1,489
    172
    May 19, 2010
    Lasalle Ontario
    I must disagree , it's from the tenting rubbing on the aluminum once the bend ends are pushed in and top comes down the tenting from just about any area will come in contact with the rails . That black powder comes off the Aluminum as it wears with rails going in and out etc. It's a S.O.B. to get off , the best I can do with mine is lighten it somewhat .
  16. karley020
    karley020 Member
    86
    22
    Apr 20, 2016
    WI
    Just a thought, not speaking from experience, has anyone tried the mr clean magic eraser on this? I know it works well on random stains. That would be my go to if bleach based products don't work.
  17. Jeepguy93
    Jeepguy93 Active Member
    504
    42
    Mar 30, 2014
    MA
    I have this cleaner i get at the dollar store its called "AWESOME" it will take that out. I use to on my pup vinyl and cotton canvas!
  18. JRnTrixie
    JRnTrixie New Member
    25
    Apr 24, 2016
    I have to give a second vote with Jeepguy on the Awesome. It lives up to it's name and yes, it's really found at the dollar store! I clean vacation homes and use it a lot and we also use it a lot at home. We actually just washed our entire pop up with it and it is so clean and shiny! Just make sure to not let it sit too long on any surface because it can make it fade or leave marks like bleach. It can also be a little potent, especially if you're sensitive to cleaners, but it works just as well if you mix some water in with it. If you're indoors I recommend leaving a window open and turning the fan on.
    As karley020 mentioned, the Mr. Clean Magic Eraser is also a great go-to product. I actually use it more than bleach. It doesn't make as much of a mess and IMHO it works better
