Help please!
Discussion in 'Wiring' started by RSH, Jan 3, 2016.
  1. RSH
    RSH Member
    38
    Jun 14, 2015
    Hi all. I pulled into our campsite last night (2008 Fleetwood Utah) and set up only to find the electrical system doesn't work. It worked fine last weekend. I plugged the camper cord into the 30 amp outlet and the lights flickered, and then everything went dark. No breakers were thrown either in the camper or on the post. Well, I flipped the 30 amp breaker on the post, flipped it back on, and the same thing happened. Again, and again. Lights flicker and then go dark. No breakers thrown. So I put a 20 amp adapter on my 30 amp cord and plugged into the 20 amp socket. Same darn thing happened. I looked under the trailer to make sure the chassis ground wire was tight and it was. I'm not an electrician so I haven't messed with anything else. Any ideas? Thanks, Robert
  2. jmkay1
    5,250
    2,074
    I'm not electrical savy myself so can't help with your problem. If you have a heavy Gage electrical cord with you that's long enough, you could try and see what happens if you use your neighbors post. At least to narrow things down a little more. A multimeter will probably also be very helpful if you have one. I have been to many campgrounds where the campground posts are the problem so first want to rule that out. Good luck, I'm sure someone else here could help more.
  3. TRR
    TRR Active Member
    448
    221
    Nov 3, 2014
    Alabama USA
    Do the 110v outlets in the camper work when you plug something in? If so, that might indicate an issue with your 12v converter. Your lights are 12v. Check the 12v fuses. Also check the wires that run up to through the canvas to the ceiling. The connection there may simply be loose.
  4. rabird
    6,904
    390
    N. TX
    use a corded appliance in the PU to determine if the 120v outlets work while the PU is plugged into shore power, if they do then move on to the 12v side, kill switch under sink (IIRC, the porch light is not wired to the kill switch), wires/plug running up to roof, ...
  5. WeRJuliIan
    906
    91
    May 15, 2014
    Sarasota, FL
    Your lights should run from your battery, with the shore power unplugged... if I'm understanding you correctly, the lights work until you connect 110, then go out?
    If you can repeat this cycle over and over then I would begin to suspect your converter... or, just maybe, are your battery connections solid? And, silly as it sounds, the right way around? (Non-LED lights don't care which way round you connect the battery, but the converter does)
    If your battery post connectors are loose or corroded, that may be the issue
  6. RSH
    RSH Member
    38
    Jun 14, 2015
    First, let me say thanks to you all for responding to my message. I checked all the connections and fuses - nothing out of place there. Then I flipped off all 4 breakers in the camper (30 amp, 20 amp, 2 15 amps), flipped the main breaker on at the post, then flipped the 4 camper breakers back on one at a time. Voila. Now I have power. I'm still not sure what the problem is/was but I will have it checked out when I get home. We never use anything but shore power - don't even have a battery installed. I suspect one of those breakers is bad or maybe it could be the converter??? -Robert
  7. Raycfe
    16,464
    2,244
    It may be as simple as a loose wire going to the breakers.
  8. WeRJuliIan
    906
    91
    May 15, 2014
    Sarasota, FL
    Doesn't the Utah have electric brakes? You might want to check on that...
    If it does, you need to have at least a small battery to enable the breakaway braking - and I believe that's a legal requirement in many places,
  9. campfreak
    campfreak Active Member
    2,023
    25
    Jan 13, 2011
    Nice re-boot. [:D]
  10. niagarafam
    niagarafam Active Member
    2,157
    Jan 25, 2014
    Our Niagara manual says that a charged battery should be connected when using shore power. I believe it protects the converter.
  11. Canufixit
    Canufixit Member
    61
    Nov 4, 2015
    From what you described - your wiring in your camper sound fine. Perhaps running high on the amp draw though. I'd say a few things to check first.
    1.) Breaker at the pole is lower amp than your panel.
    2.) Breaker at the pole is defective.
    3.) Voltage at the pole is low (low voltage = higher amp draw).
    4.) You have a high initial draw in your camper (i.e. Fridge and AC and heaters/fans are all on but once started are under max amp of the Pole breaker
  12. RSH
    RSH Member
    38
    Jun 14, 2015
    I've isolated the problem to the 12V circuit. I was able to do this because the propane detector and the overhead lines started acting up simultaneously. I took out the 30 amp fuse on the battery circuit side so they no longer make noise/blink. All of the 110V stuff works just fine. I bought the camper without a battery and just figured I didn't need one. But from these posts it seems I may have been wrong. I guess I may have to invest in a new converter and a battery when I get home. Does anyone know if such a converter is even available given that Fleetwood went under? Or will another make/model work? Thanks again, Robert
  13. kitphantom
    12,060
    1,104
    Converters are one of the items that are not brand-specific. Many brands use the same converters
  14. RSH
    RSH Member
    38
    Jun 14, 2015
    How complicated is the installation of a converter? And about how much do they cost? Any suggestions on brands?
    Thanks, Robert.
  15. Ductape
    Ductape Well-Known Member
    1,138
    131
    Jun 12, 2013
    Install a battery and hard wire a 12v smart charger into your 110v circuit.
  16. JT105
    JT105 Member
    183
    Jun 29, 2015
    Our old PUP had a flaky breaker and I had to reset it after plugging the cord int the campground power.
    Not having a battery could cause an issue with the charging part of your converter but shouldn't effect the 12V outputs. If the 12V output is flaky, it is either a loose connection or it may be time for a new converter. They do go bad after a while.
  17. rabird
    6,904
    390
    N. TX
    From WFCO http://wfcoelectronics.com/faq/ I ass-u-me you have a POWER CENTERS: WF-8700 SERIES
    Does the converter need a battery to operate?
    No. The battery works in conjunction with the converter to supply DC power to the RV. A battery is typically only necessary if you do a lot of dry camping or have slide-outs and/or a leveling system.
    electric brakes need a battery when the brakeaway pin is pulled as all @#$% breaks loose!
  18. Hoosier Daddy
    Hoosier Daddy Active Member
    1,331
    Jun 24, 2014
    Boy Robert, I'd be doing a lot of checking before I pulled the trigger on a new converter. Especially on an '08.
    I would say Canufixit is spot on with his suggestions and I'll add Ohms law says higher resistance equals higher amperage. In other words a loose / corroded connection. Now that you know exactly which circuit your dealing with, make sure everything is tight and clean.
    If you do buy a new converter, I might take your old one if your just going to throw it in the landfill. [;)]
  19. niagarafam
    2,157
    Jan 25, 2014
    I agree with "H Daddy." We have had a ton of electrical issues that have been mainly due to grounds, loose and frayed wires, and a faulty GFCI. Keep it simple and work through the obvious easy things first (ground, wires, and fuses, and breakers). We added two new grounds that have helped a lot. One is at the current limiter for the lift motor, and the other is on the tongue off of the battery. At one point, I was convinced it was our converter, but I was schooled to go throughout the basics first, and I am glad I took the lesson. Start simple and be thorough.
  20. TRR
    TRR Active Member
    448
    221
    Nov 3, 2014
    Alabama USA
    Just a thought but have you located the wires that would connect to a battery if you had one? Is it possible that they are touching each other or that the positive lead is intermittently grounding to the frame? If they're just flopping around loose that could certainly seem to cause some funkiness on the 12v side of things.
