HELP. SENSOR????
Discussion in 'General Camping Discussion Forum' started by Raven27, Jul 3, 2019.
  1. Raven27
    Raven27 Member
    49
    Mar 12, 2019
    Western Massachusetts
    So I was closing up pop up and this thing had. A little metal tab that fell of . I'm assuming it's a sensor that tells the brakes that the camper is closed all the way so I can tow it. The black thing, hopefully pictured, was holding a la metal, longish tab that seems. To make a connection when its closed. What is i . Where do I get a new one, and is it necessary?
  2. Raven27
    Raven27 Member
    49
    Mar 12, 2019
    Try again
  3. PopUpSteve
    PopUpSteve Administrator
    18,907
    1,658
    Dec 22, 2002
    Malvern, PA
    Looks like the kill switch for the inside lights.
    • Was this inside or outside the camper?
    • What Make & Model camper do yo have?
    neighbormike likes this.
  4. tombiasi
    5,528
    1,193
    It wouldn’t have anything to do with the brakes.
  5. nineoaks2004
    7,557
    3,272
    Dukes, Fl
    I agree with Steve, it is probably the brake away switch for the brakes, if hooked to a battery ( it needs a 12 volt battery to work) it will energize the brakes if the unit breaks away during hauling the unit on the road.
  6. joet
    4,884
    1,013
    This is not a brake away switch. Your break away switch is mounted on the tongue with a cable attached.
    tombiasi likes this.
  7. Raven27
    Raven27 Member
    49
    Mar 12, 2019
    I guess it was outside the vinyl, but Inside the roof framing. Is. Skill switch so I dont drain battery while driving?
  8. tombiasi
    5,528
    1,193
    Does it kill the ceiling lights?
  9. Raven27
    Raven27 Member
    49
    Mar 12, 2019
    I have no idea. no battery hooked up and we were closing it up to move it. I could check on the weekend
  10. tombiasi
    5,528
    1,193
    The kill switch shuts off the ceiling lights when the camper is closed. It has nothing to do with saving the battery while you are driving. It’s to prevent the bulbs from burning the canvas.
    neighbormike, kitphantom and bheff like this.
  11. bheff
    bheff Well-Known Member
    1,184
    626
    Feb 24, 2011
    NW Arkansas
    I agree with this....kill switch for the lights. Has Zero to do with the brakes.
  12. Raven27
    Raven27 Member
    49
    Mar 12, 2019
    Ok. I dont have a battery hooked up so I'm. Assuming I have no issue, or would power from vehicle power lights while driving? That is if I left them on. I also converted to al LED's
  13. tombiasi
    5,528
    1,193
    LEDs won’t get hot
