Help! When DampRid attacks!
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by mostlyok, Nov 23, 2011.
  1. mostlyok
    mostlyok We're Mostly OK!
    1,077
    Jun 5, 2005
    Sarasota, Florida
    We use good old Damprid and it works very well keeping out the moisture.
    But I had the container tip over sometime in the last month or two and it is soaked into the "wood" of the upper sink cabinet when it was in the down postion. Now it is swelling and absorbing moisture into the partical board "wood". HELP! what should we try to get it dried out?? [:O] We have towels on it all but I don't know....
    Thanks!
    Heidi
  2. bigdad
    bigdad Active Member
    3,577
    Mar 5, 2007
    Springfield Kentucky
    Is there a 1-800 number on the can that you can call and ask them how you can stop it if they can't help you might have to redo the upper sink cabinet.
  3. 1madscot
    1madscot Member
    256
    Nov 6, 2010
    Bad news, but you'll want to remove that wood as soon as you can. The liquid that forms with the damp rid is corrosive, and can destroy the wood it soaks into. You won't be able to save the piece it's effected to this point, but by removing it now, you can save the rest of the structure. Then you can make a new one to suit your needs better, a pop up project to share with us :) (just trying to look for a bright side here)
  4. Richard
    Richard Take kids camping. It's great for you and them.
    278
    Dec 11, 2007
    Blue Ridge Mountains, Tennessee
    Well said, madscot! Particle Board is just silly for use in areas where it can get wet, but it's cheap and so many manufacturers use it around sinks, etc. Plan on rebuilding that cabinet with plywood or something similar.
  5. mostlyok
    1,077
    Jun 5, 2005
    Sarasota, Florida
    I emailed the company and the nice man said there was nothing you can do. You have to remove the particle board. Stupid stuff....... (the Particle board, not the Damprid.) 1/4" Particle swells to 1" thick when it gets salt in it and just keeps sucking in all the water from the air!
    Damprid is made of-Sodium Chloride, Potasium Chloride and Calcium Chloride.
    Fortunately the rug the galley was sitting on kept the stuff from spreading to other areas.
    We had towels to keep it from spreading, fortunately it is only the face and not the entire cabinet.
    We took the face off and Paul is going to make a replacement out of Ply. We have ordered some Oak Contact paper and will cover with that.
    I have to say with the face off, I could go crazy and put in glass front doors with roll out shelves....Hmmmm.
    I think we will just recreate what is there, for now, but it does make one think. I might plan if for the future. Oh the possibilites. [:D]
    I will be putting the Damprid container in a bucket from now on that's for sure.
    Happy Thanksgiving!
  6. 1madscot
    1madscot Member
    256
    Nov 6, 2010
    If I may...rather than using ply and a picture of oak, why not get some oak faced ply? It will be a better quality ply, fewer voids, and the end result will make you much happier. Not a huge cost difference, and you can often find 1/2 and 1/4 sheets.
  7. mostlyok
    1,077
    Jun 5, 2005
    Sarasota, Florida
    We managed to get the face off and rebuild it. We think we did a "MostlyOK" job of it. Just waiting for the Contact paper to arrive to finish the face.
    I agree, but we needed to get it fixed for now. We installed it with screws, so we could always redo and improve later if we see some nice materials. We are not so afraid of it now that we had to take it apart and rebuild it. Gives me too many ideas for upgrades.......
    http://community.webshots.com/album/581876484ZdhXdC
    I am feeling much better now. :)
  8. rawlus
    rawlus New Member
    269
    Jul 24, 2011
    I place damp rid on the floor and I duct tape the container into position to ensure it won't accidentally tip.
  9. mostlyok
    1,077
    Jun 5, 2005
    Sarasota, Florida
    Got 'er done!
    I finally finished the repair to the 'kitchen' [8D]. The DampRid spill caused a lot of hassle. Particle board sure does soak up the chemicals [:(O]. And DampRid says it's hopeless. I desparately removed the damaged face to prevent the spread of more damage. Next I used some plywood to replace the panel. After lousy working conditions (and no time off) I was able to get to the final fix done this weekend. I purchased some veneer and cut it to rough size. Then used contact cement to cover the plywood. Next was trimming out the holes and edges. I learned this part many years ago, working with repairing pianos (my first job! :grin:) .Use a rasp to scrape the edges, removing the veneer right at the edge. Finally, with a lot of luck, the polyurethane (MinWax) stain matched colors perfectly! I haven't worked with wood this way in a long time. I'm feeling really good [:D] about the results.
    Pictures at http://community.webshots.com/user/mostlyok under "Upper Galley Repair".
  10. 1madscot
    1madscot Member
    256
    Nov 6, 2010
    OUTSTANDING! You did one heck of a repair job there. [:D]
  11. mickkjhc
    mickkjhc New Member
    24
    Feb 11, 2012
    You can find a similar product with the same dehumdifying properties as Damprid at the Dollar Tree, in a spillproof container. It sucks moisture out of the air for about 2 months before needing replacement. We use these for our closets, but they are also cheap and effective (and won't spill) in campers.
  12. Jayko
    Jayko Jayco 141J aka Big Bertha
    1,263
    Jul 10, 2012
    Next time put it in a wash bucket. If it tips it will stay in the bucket
  13. RotnMom
    RotnMom Am I there yet?
    4,125
    19
    Apr 4, 2011
    I keep my DampRid in a the 5 gallon bucket that acts as my loo while in storage and for travel. Bungee'd the handles so nothing is going to move! [;)]
    But truth be told, before all these chemicals were being used heavily, I grew up camping and using small bowls of plain charcoal in several places to absorb moisture.
    [:D]
  14. papachaz
    papachaz New Member
    2,821
    Jun 26, 2011
    wow mostlyok, you did a great job with that! and, i have to admit i did some snooping around in your pics [:D] i absolutely LOVE the way you've got patches from all your camping trips, that is AWESOME! this year when we bought the TT, we decided we'd get a small decal to stick on the outside to document our trips, and it's amazing how many places don't have them! but, i don't remember going somewhere that didn't have the patches, so maybe we'll start doing that, awesome, thanks for sharing your photos with us!
  15. babar
    babar Don't throw effort after foolishness
    153
    Jul 23, 2012
    Wow! Good to know... I'll have to keep that in mind if/when I need to use damprid again.
    I'm feeling very fortunate right now that my camper is mostly steel and aluminum. I haven't yet found the rot, I'm sure it's there somewhere.
