Help. Which Battery Post to Connect White, Black & Green Wires
Discussion in 'Wiring' started by ccombs0708, Oct 19, 2021.
  1. jmkay1
    7,075
    4,139
    Just throwing this out there. I have electric breaks with a break a way on my camper and have a blue wire which needs to be connected to the positive to operate my electric breaks. Jayco I believe only uses hydraulic breaks unless the prior owner changed it out. Definitely try and follow the wire.
  2. tombiasi
    6,675
    2,240
    The blue wire should not be connected to positive, it should be connected to your brake controller.
  3. Clemens
    Clemens Member
    51
    Nov 2, 2019
    FL - Florida
    If you have an ohm meter, measure the green wire to the chassis. It maybe connected to that. In DC circuitry the black wire usually denotes the chassis wire. Again, use your ohm meter to see if that is connected to the chassis. If not, check the white one. Do not just connect wires to the battery without knowing what is what: You can do a lot of damage or even start a fire.
  4. Jim Keeling
    Jim Keeling Member
    69
    Jul 22, 2021
    Georgetown, Tx
    Grouned to body
  5. kmbarreiros
    kmbarreiros Active Member
    185
    98
    Jun 17, 2014
    Fairhaven, MA
    Green wire many times is used for the running lights around the pup.
    Have you connected the 4 pin connector to your tow vehicle to verify all the lights work?
