Help with lift system "covers"
Discussion in 'Miscellaneous Repairs & Maintenance' started by neeners73, May 16, 2016.
  1. neeners73
    neeners73 New Member
    21
    Apr 30, 2016
    I am looking for some help - I have a 1987 Palomino pop up, and on the lift arms are little plastic protective covers. A couple of them are cracked, and they get caught on the outside screen when we are packing up, so I want to replace them (I purchased some). The problem is, they are riveted to the lift arms. What's the best solution to attach the new ones? I don't want to accidentally damage the lift arms and I have no idea how to remove rivets.
    Here's one that's in relatively good shape: https://db.tt/S9RJonVZ
    Here's what I want to replace: https://db.tt/fspsCnFk
    Any advice is much appreciated! Thank you.
  2. o740c314i9xt
    o740c314i9xt Member
    33
    Sep 8, 2015
    Use a drill bit that is slightly larger than the whole in the rivet. The head will be cut off and the blind end will fall in; or you may need to push it into the lift arm. Then place the new cover, using a POP rivet gun, insert the new rivet in the hole and pump 'til it pops.
    Blind rivets
  3. neeners73
    21
    Apr 30, 2016
    Thank you!! Much appreciated!
